AH FabricationsBadger5
Results 1 to 19 of 19
Like Tree3Likes
  • 1 Post By aragorn
  • 1 Post By Jason.s
  • 1 Post By aragorn
Thread: Learning my Quattro, but need guidance
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    391
    Hey All,
    I'm getting more familiar with the car now, have noticed when cornering hard to the right. and the road is slightly rough, I can hear a single slight knock in the back. To the point it sounds like something is sliding around in the boot, checked this nothing in it. Sound like the ARB starting to wear? it's only when the N/S/R is loaded. You can't feel it, just hear it. When the corner is very smooth nothing lol.
    I've gone through the whole rear of the car and can't find anything loose. I've released the seats and placed them back in case they weren't locked in correctly.
    My front seats squeak a lot, I've searched the forums high and low but can't find any advice. I really don't wanna change them but just wondered if this is common and put up with or can be oiled?
    Also, the Quattro system on my car is it permanently on or just rears activate when needed?
    Thanks for your help.
    Ash
    (2000 TQS Avant AJL Engine)
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    I found on my saloon that the tool kit wasnt clicked in correctly and would come loose and rattle in the cage.
    You checked the springs and bushes ??
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    405
    My seats squeak a bit. On mine it's the seat belt clasp touching the seat bolster, moving the clasp stops the squeak. Pretty sure Quattro is perminantly engaged.
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    391
    the knock has vanished :-) so must have been something I fixed by checking all the fixtures and fittings. seats though are a real pain. I'm tempted to strip them to see what can be done.
    How does the quattro system work?
    Thanks all.
    Ash.
    jcb
    Sep 2005
    uk
    4,077
    always on.
    get some alcantara and stick a small patch to the seat belt clasp. stops it squeaking against the seat.
    internal knocking could be any manner of things in cubby holes and spare wheel wells.
    external knocking will or could be one of numerous bushes in the rear that is worn.
    I had a knocking rear diff hanger on load unload of power
    Aug 2010
    3,138
    My exhaust knocks against the nsr arm on a sharp right or bumpy right turn think the flexi and mounts are past there use by date lol
    Im just putting up with it till i get round to getting a custom 3" system fitted.
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    391
    Quote Originally Posted by Bradderz_1988 View Post
    My pickup used to do that, more so in the rain oddly! went in 3 times they never could fix it either lol
    Knock def gone lol.
    Just need to figure a fix for seats. and annoying internal squeak from the back seat area then sorted.
    My wife want's to know what the strange little red lights above the rear view mirror are for? Damn'd if I know lol
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    Ambient illumination in the cabin at night!
    Iceash likes this.
    TD5 Land Rover Defender build
    May 2010
    Bedford
    2,877
    Sexy mood lighting for those cheeky layby stops at night
    Iceash likes this.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    391
    lol far to dim for that surly!
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    391
    Quote Originally Posted by jcb View Post
    always on.
    Checked tool kit, it makes a blood racket!! I shall try packing it with bubble wrap at least that should deaden the sound lol
    Aug 2010
    3,138
    I found if you press the cage underneath towards the tool box it would click and the tool box was secured rather than clinging on for dear life so it wouldnt bounce around the cage !!
    "Stick a V8 in it!"
    15,385
    its not supposed to be a floodlight, just some soft illumination to light up the console at night.
    Iceash likes this.
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    391
    I don't quite follow. Mine is polistyinene so not sure that would work?
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    241
    Quote Originally Posted by Iceash View Post
    Knock def gone lol.
    I think they have something to do with the anti dazzle rear view mirror.
    Should be a little sensor in the centre of the mirror to act as a sensor
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    Bradderz avant has a wheel well tool kit shouldn't rattle when clamped in though
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    Aug 2010
    3,138
    Ahh right that makes sense then
    "Stick a V8 in it!"
    15,385
    Maybe its missing the plastic cover and clamp?
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    391
    it's the tools more than the case that are making the rattling round :-)
  1. Learning the hard way....
    By Tom_B in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th February 2012, 16:41
  2. I'm learning, but.....
    By A3T.IAN in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th December 2009, 16:40
  3. I am learning SLOWLY.
    By crypric23 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st November 2009, 21:32
  4. Guidance with purchase A4 Avant 2.5TDI Quattro
    By pschmitt in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th April 2009, 09:18
  5. Learning to swear
    By TDI-line in forum General Chat
    Last Post: 12th May 2005, 14:42
