EM TuningMonster Motorsport
Results 1 to 9 of 9
Thread: Turbo chatter
    Apr 2012
    12
    Turbo chatter
    HI everyone,
    My rs turbo had major major turbo chatter I've been looking at videos of s4s and can't hear anything from the turbos ? do you get turbo chatter or just settle for a d/v ?
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,135
    Just DV valves really as you choose the risk of snapping the turbine shafts, set of forge DV and a modded airbox or open filter will give you a more audible dumping sound.
    Apr 2012
    12
    sorry i might be mistaken but are you saying that having d/vs could cause problems with your turbos ?
    Aug 2010
    3,135
    No sorry i didnt really explain these cars dont like dump valves as the air is metered so it causes the car to over fuel as your dumping the air to atmosphere so they have DV or diverter valves that redirect the air to the intake so theres no fuelling problems, the only way you can get the chatter/compressor stall noise is by pulling the vac lines of the DV's so that the turbo's stall hence the risk of snapping them, hope that all helps.
    Apr 2012
    12
    ahh i see what your saying. top job cheers
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    405
    There are loads of threads on the net about turbo chatter. Many in the turbo Nissan world run with no dv at all (myself included and at 1.4 bar as well) with no ill effect. Are the turbo set ups on Audi's a bit weaker?
    I'm not saying it's a good idea and have zero intention of doing this on my audi by the way
    Apr 2012
    12
    i had no dv on my rs running at 21psi with anti lag No problems with the turbo at all
    Aug 2010
    3,135
    It all depends on the shaft diameter as the kkk ones arent ideal in comparison to a garrett.
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    405
    That makes sense. I use an uprated garret unit on my other car
  1. Turbo chatter
    By shanejess in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th November 2013, 18:34
  2. Turbo Chatter
    By sam4191 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th June 2011, 19:53
  3. Another turbo chatter question
    By paulsaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd June 2011, 20:17
  4. Turbo chatter at low revs, DV fault TFSi?
    By S-Liner in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 13th June 2011, 19:02
  5. DV chatter
    By BigBird in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th January 2011, 16:35
