Volks AutosBadger5
    May 2010
    Bedford
    2,877
    Odd noise from only one side on hard cornering
    Last few weeks i`ve noticed a whirring/droning sound from the front left on hard right hand corners. Its perfectly silent on normal driving whether it be cornering or driving straight. Thinking it could be the cheap euros wheel bearing i put in when the wheel came off last year. Could that be the issue? Possibly hasnt completely let go yet but the added strain from fast cornering and bigger weight shift to that corner could be showing up a weakness of sorts?
    Looked across the net and it varies from outer tyre block noise, wheel bearings or dried up cv joints. Theres no splits or visable leakage from the cv boot. Tyres arent that old and have never done it plus its only one side so cant be that plus i`ve never had it happen on previous cars so its only pointing to that one thing?
    Plus the cheap Euros bearings are a bit prone to failure so i`ve heard.
    Any other ideas or am i right in thinking its the bearing?
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    Jun 2010
    warwickshire
    93
    would say wheel bearing but if the noise is only happening on corners then i would go with cv joint not a hard job just a messy 1
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,350
    my old FWD had a dodgy bearing that only made noise on cornering and only around 50mph.
    You'd get a wa-wa-wa-wa-wa-wa noise when going round corners in one direction, and it'd go away when you streightened up again.
    I suspect it would have got worse had i ignored it, but i had the hubs off doing the arms so i just nailed two new bearings in.
    TD5 Land Rover Defender build
    May 2010
    Bedford
    2,877
    Yep pretty much exactly that^!
  1. Replies: 10
    Last Post: 23rd March 2010, 15:20
  2. Replies: 5
    Last Post: 1st March 2010, 22:44
  3. Grinding noise when cornering
    By vbking in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th December 2006, 13:43
  4. Odd noise
    By petewon in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th August 2006, 02:37
  5. Replies: 1
    Last Post: 10th May 2006, 01:19
