Chris NottSky Insurance
    Apr 2006
    A, A
    269
    Why why why is my setup this way???
    Just to understand a little why the owner before me has got this setup to the front hubs/brakes etc.
    Removed front wheel (found studs comes out with only a few full turns)
    Then seen 10mm hubcentric spacers with spiggot ring attached
    Front brakes are MOVIT 4M6 calipers
    Front brake discs I have now found out to be S4 B6 vented and EBC grooved? (just going off specs sheet)
    Why the spacers? is it to allow the calipers not to hit the wheel?
    Surely the studs should have been replaced with longer ones no?
    Just seems abit over kill and dangerous with the stud situation.
    Also can someone shed some light on this (on spec sheet for car I got given when I bought it) =
    Original MOVIT bells supplied, rotors are £300 each??(no idea what bells are?well not the kind on brakes anyway)
    Andy
    Apr 2012
    34
    Only a few turns and the studs were out? If you use 10mm spacer personally I would use 10mm longer studs........
    Spacer may have been to clear the caliper, try it without spacer and check. Maybe just to widen track of car.
    Bells - normal brake discs come with the bells and rotor as one part, brakes like yours come as 2 parts. The rotor bolts to the bell and the bell bolts to wheel. Different bells for you brake setup and car can be used to change offset amongst other things, depending on what you use the car for.
    hth
    Apr 2006
    A, A
    269
    Mine discs are just S4 B6 vented and not in 2 parts, just checked the clearance from the outside of the caliper to the inside of the alloy with the spacer fitted and thes about10mm gap. so see now why the spacer is used.
    Will order some longer studs asap.
    Andy
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,907
    They must already be longer, as the stock bolts wouldnt even engage one turn with a 10mm spacer.
    6 turns is what you want though.
    10mm is the thinnest spacer that can be properly hubcentric on these cars, so even if it only needed 4 or 5 mm some people will choose to go 10mm so they can use the decent hubcentic spacers.
    TD5 Land Rover Defender build
    Apr 2006
    A, A
    269
    Will order some today, thanks guys
  1. My av setup
    By afcjay in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 5th September 2011, 01:08
  2. Audi A3 1.9tdi 2000 front brake setup upgrade, Will B5 S4 setup work?
    By silver99s4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th June 2010, 14:33
  3. Setup
    By 6andy69 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th December 2008, 23:29
  4. Swap my double din setup for a single din setup
    By <tuffty/> in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st December 2008, 21:19
  5. Quite a setup!!!!
    By stapo69 in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th June 2008, 13:08
