AH FabricationsEM Tuning
Results 1 to 20 of 20
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,030
    Rear Brake Upgrade
    Its not something I'm thinking of do cause I can't see the point for me but its something that I decided to look in to for cause I don't really have much else to do.
    I did a simple google search and not much came up, just S4s and quattro.
    Nothing for 2wd so I got on to ETKA and thought I'd cross check some part numbers and see what fits on to what.
    I might wrong, which is fine, I'm just information gathering and brain storming I guess.
    Audi B5 2wd rear discs are 245x10mm.
    Carrier part number 8E0 615 425. This is also used on A4 95-08, A4Q/S4 01-08, A6 98-05, A6Q/S6 98-05 and some VWs.
    Calliper part number A4 95-01, A6 98-05, A6Q 02-05 and some VWs.
    Sticking with the carriers, if you do a search for the A6, the carriers also fit on one running 255x10mm.
    Am I right in thinking that the rear carriers from a 2002 A4 will fit on to a 2wd B5 and let us run 255 rear discs?
    I know the callipers will need changing but if I'm reading ETKA right it looks like it works...................Unless I messed up the part numbers and its just the pad retaining pin.
    Any one got any thoughts or any thing?
    I'm off to search for more random things.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,389
    The carrier wont go over a 255mm disk on a B5.
    Theres presumably a diffeerence in the mounting points on the A6 axle, allowing the same carrier to give it the extra 5mm?
    TD5 Land Rover Defender build
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,030
    I think I miss explained.
    the 245 carrier that fits the B5 is also used on the A6.
    that same model A6 also runs a 255 disc.
    since the 245 carriers fit both, I assume the 255 would?
    that's also my thought but if there is a difference it could be copied with spacers?
    hmmmm
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    You been searching like mad scott ?? your guna find a way arent you lol
    Are the stub axles identical then aswell ??
    Another trip to the scrappers for you then eh lol
    "Stick a V8 in it!"
    15,389
    ah gotcha.
    The problem is the A4 uses a 1 piece hub/disk, whereas i suspect the A6 will have seperate hub and disk like a Quattro?
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,030
    Quote Originally Posted by Bradderz_1988 View Post
    ah gotcha.
    I'll get my laptop again. brb
    Aug 2010
    3,138
    Lol
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,030
    The hub from the 2002 A6 is used in the passat 97-2005 and the points go to Aragorn with the 1 piece hub disc like the quattro.
    Rubbish!!
    So close...........But its the same carrier.................ahhhhhhhhhhhhhh
    Aug 2010
    3,138
    Just have done with it scott and get a quattro Lol
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    241
    Is it just me or do the rear calipers keep binding?
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,030
    I got no need for one and this motor has sentimental value, plus its fun trying to figure this out.
    It looks like that every other motor that uses the 2wd stub axle is older than 2000 and discs are no bigger than 245mm.
    If the carrier fits and the callipers fit, I doubt we'd/I be able to get the correct discs to fit.
    O well.
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,030
    Quote Originally Posted by B5 BIKER View Post
    Just you mate.
    All good over here. lol
    "Stick a V8 in it!"
    15,389
    Audi 100 stub axle
    Facelift S4 disk
    Facelift S4 caliper
    Make it fit.
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,030
    Audi 100 stub axle
    Facelift S4 disk
    Facelift S4 caliper
    Make it fit.
    Whats the difference between the 100 stub axle?
    They use the same part numbers.
    May 2010
    Bedford
    2,877
    Didn't we work this out to use the standard stub axel but using an early a6 hub or something so you can use a normal disc instead of a disc with built in bearing like we do now? Then you could use the 255mm disc or if the s4 calipers/carriers bolt on fine to the fwd mounting position then upgrading to the vented discs. If they weren't Audi only I'd try to order and see how it goes but if it fails Audi probably won't let me return them. Euros even with my discount were about the same as the genuine prices. Plus they'll need to be pressed onto the stub axels won't they?? Which causes more problems with stripping and possibly having to return if wrong.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,030
    Quote Originally Posted by Jason.s View Post
    what is the total price?
    May 2010
    Bedford
    2,877
    Like 60-70 plus vat each I think at cost price lol.
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,030
    8E501611j Audi A6 02 Hub with wheel bearing £143.41
    8E0615425F Audi A6 02 Carrier £77.12
    8E0615423A Audi A6 02 Callipers £172.37
    The rear axle hub/stub set up changes around 98 from a stub axle to a hub.
    The rear axle beam also changed around that time.
    If the hub and stubs are interchangeable then this will work.
    "Stick a V8 in it!"
    15,389
    sorry i wasnt very clear there.
    The Audi 100, and 95-97 A6 uses the same stub axle as the A4, however instead of the hub being built into the disk as it is on the A4, its a separate component. 4A0501653C
    My suggestion is that by fitting that hub to the A4 stub axle, it then allows you to use a normal brake disk. You may need to space the caliper mounts to sort out any offset issues that may arise, but it should be possible.
    The best bet would be to find a pair of these hubs from a scrapyard, rather than trying to buy them new. Retail price on ETKA is £130 each!
    Aug 2012
    telford
    211
    Doing this what would b the easiest disc and caliper setup to use? Could you use original caliper?
  1. Rear brake upgrade A3
    By Plunky in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd February 2010, 19:45
  2. Rear brake upgrade
    By Joeleol in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd September 2009, 09:32
  3. rear brake upgrade
    Last Post: 15th August 2009, 20:46
  4. rear brake upgrade on a6
    By dummi in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 8th October 2005, 17:42
  5. About rear brake upgrade.
    By Theodore in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2004, 07:51
