Volks AutosChris Nott
Results 1 to 15 of 15
Thread: S3 Callipers
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,655
    S3 Callipers
    I got a set of S3 brakes to convert my brakes from 288mm to 312mm.
    Will the S3 callipers fit?
    A4 B5 Double Din, RNS-d, TMC, Full Sports Leather Heated with Leather Door Cards and Lower Door trims all for sale.
    Audrey's Build Thread
    RIP Audrey. She's being broken down.
    New Car, New Thread.
    Scott's Akoya Silver A8
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,065
    i asked the same question and the answer is yes but aragorn said they use a smaller piston than the a4 ones
    so as long as you have ate calipers in good working order already there's no point it would just be more work bleeding brakes
    i am curious as to what difference a couple of mm in piston size makes, never heard of s3 owners swapping to a4 calipers
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,871
    I dont think they do scott as they have straight screw in fitting on the calliper where as ours iirc have a small brake pipe and a union fitting wear the pad wear indicator connector is if you got some custom brakelines then id say they probably may fit but i just used the existing caliper as tgere almost identical.
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,904
    Yeh, the stock calipers have 57mm pistons, whereas the S3/TT ones have 54mm, so you'd actually reduce your braking effort.
    As bradders says the brake pipe fittings etc are a bit different.
    Just keep the stock A4 caliper and use the S3 carrier.
    You can then stick the A4 carrier on with the S3 calipers and put them back on ebay as standard 288mm A3/golf brakes
    TD5 Land Rover Defender build
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,655
    Quote Originally Posted by olds_kool View Post
    I'm not worried about bleeding. I'm replacing the fluid.
    The size difference on the pistons will effect peddle travel but can't see how it will effect the braking effects.
    I'll check these callipers and mine and I'll stick with the best set or even rebuild a set, I got enough time.
    Which pads do you I order?
    I don't want to order normal 288mm pads cause they won't use the full disc surface, do I order S3 pads?
    Aug 2010
    2,871
    The 288mm pads use the same disc surface as the 312mm ones, heres a pic of a caliper and you can see what i mean by the fitting on our caliper.
    "Stick a V8 in it!"
    14,904
    Simple physics.
    Force = pressure x area.
    Pressure is related to the force your leg would apply to the pedal.
    Area is the size of the piston on the caliper.
    given area = pi x r^2, going from 54mm to 57mm is about 10% reduction in braking force for a given pedal pressure.
    going from 288 to 312mm disks only gains you about 8%.
    You dont really want to be using the S3 calipers.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,655
    Quote Originally Posted by Bradderz_1988 View Post
    I'm only questioning it cause when I looked at these S3 brakes the pads covered the whole surface of the disc.
    When ever I've seen any one do a 288-312mm conversion there pads never use all the surface of the disc.
    I'll try and find some pics.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,655
    Simple physics.
    Got it.
    I wont.
    "Stick a V8 in it!"
    14,904
    Scott: the pad surface area is the same, it just sits further out from the centre with a bigger ventilation gap.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,355
    You probably have 280's on there scott dont you?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,655
    From Jason.S build thread.
    Unless I'm missing something, I don't think thats a 288mm pad.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,655
    Quote Originally Posted by Byzan Photography View Post
    288mm, I checked it a couple of times.
    "Stick a V8 in it!"
    14,904
    110 TDi's got 288's.
    It is a 288 pad.
    On the 288 disks theres not as large a gap between the central hub, and the pad surface:
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,655
    It is a 288 pad.
    Ahh ok.
    That makes sense.
    Ta.
  1. Painting Callipers
    By willowsdad in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th August 2013, 14:10
  2. VW Touareg 6 pot callipers on B6
    By YT. in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th March 2012, 18:10
  3. Painting Brake Callipers...
    By Leglessmonk in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th October 2011, 12:31
  4. Painting Callipers
    By TM in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th August 2011, 22:04
  5. Options for better looking brake callipers...
    By PNH80 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th March 2008, 09:00
