EM TuningSky Insurance
    Feb 2012
    21
    How to remove the inlet manifold? 1.8
    Hi All
    Ive found i have the usual cracked crankcase breather elbow which it tucked tight in under the inlet manifold, so does anyone have a guide with pics maybe on how to remove the inlet manifold so i can fix this up?
    Stew
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,866
    Fairly straight forward theres a support bracket on the block to manifold a few 10mm nuts at the head, intake pipe and throttle cable a few connectors iirc its a bit of a tight pull to get it out a bit of persuation helps. Was a while ago so may have missed some things cant remember if i left injectors and rail in or took them off the manifold.
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    gmx
    Feb 2009
    Sydney
    132
    Remove the fuel rail, throttle body, move the coolant res out of the way, unbolt the IM and slide it out.
    Try get away without removing the coolant crossover pipe and emptying the coolant.
    To work on the crankcase stuff, you might get away just removing the throttle body/throttle body hose and moving the coolant res out of the way.
    I'm also going willing to guess but haven't confirmed, working on it from underneath might be easier than going through inlet removal...
    00 A4 1.8TQS GP MT AJL
    JHM SSK | FX300 + 16lbs FW | Milltek Dump back
    17*8 BBS RK | Deka ETX20L | Vogtland GT 575F/675R | H-Sport 35mm(F)/22.5mm(R) ARBs
    034 Engine Mts | Stern Snub/ Rear Diff Insert/Power Ring
    GT2871R - 13psi | Uni 415cc@4bar | 034 3" DP | 034 HFM | 034 TIP | Profec B Spec II
    Feb 2012
    21
    cool thanks guys will have a bash soon.
  1. s4 inlet manifold
    By jutlis 3.0 in forum For Sale/Wanted - Audi Parts
    Last Post: 17th February 2012, 19:44
  2. How the hell do I remove the Inlet Manifold?
    By baynesey in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th August 2011, 20:43
  3. Inlet manifold.
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st August 2011, 23:14
  4. Inlet manifold (A3,S3)
    By emery1990 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st October 2009, 20:22
  5. Inlet manifold help
    By big_mo in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th October 2009, 10:06
