Volks AutosBadger5
    Mar 2012
    Durban, South Africa
    22
    Visit PelicanBlue's Instagram Channel
    2.8 30V starts turn of key when cold, but struggles when hot
    Hey guys.
    My avant starts literally with no need to touch the accelerator pedal..in the mornings, that is. Despite the weather.
    However, after being driven until it reaches normal operating temperature, it struggles to start again.
    on the 3rd attempt usually, and with the pedal halfway in.
    I havent run a VAGCOM but what would the likely culprits be?
    thanks in advance.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    Faulty coolant temp sensor would be the first port of call.
    TD5 Land Rover Defender build
    Apr 2012
    Yep,would vote for that as well,so common problem on all VAG's.Regards!
  1. Turbo + cold starts
    By sting3rr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th January 2012, 23:44
  2. Oil & Cold Starts - Good Advice from Opie Oils
    By oilman in forum General Technical / How To
    Last Post: 18th November 2010, 12:08
  3. 1.9 tdi starts rough after cold nights
    By Wheeler97 in forum Diesel forum
    Last Post: 4th January 2009, 23:25
  4. A/C is either cold or too hot
    By fourcircle in forum Air Conditioning
    Last Post: 13th November 2008, 22:14
  5. 30v v6 2.8 Owners lend me your "ears" - Cold startup noise
    By imported_ZeroK66 in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th October 2005, 19:26
