Badger5AH Fabrications
Results 1 to 9 of 9
    jcb
    Sep 2005
    uk
    4,077
    pad warning light
    some w@nker has pulled the sensor wire out of the loom so that only the ABS wire is left.
    Can I bridge this elsewhere to get rid of the bloody light?
    I didnt have a chance to look properly but where does the front ABS/Pad sensor plug in on the inboard side?
    engine bay or am I missing something in the wheel arch?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    Pop the ABS wire grommet out of the wheel arch, and pull the loom thru into the wheel arch.
    There should be a plug for the ABS wire, and next to it the plug for the pad sensors.
    Worst case you can short it to ground at the back of the clocks.
    Having said that, do you have digital or analog clocks? Your earlier post about the CTS suggested it was pre-2000, meaning analog clocks?
    If its analog then you can code it out rather than have to short it out.
    TD5 Land Rover Defender build
    jcb
    Sep 2005
    uk
    4,077
    analog pre 2000
    how do I code it out?
    cheers
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    If youve got vagcom just remove the option in the soft coding for instrument cluster
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    "Stick a V8 in it!"
    15,370
    Audi A4 (8D) Instrument Cluster - Ross-Tech Wiki
    That suggests you subtract 1 from the first two digits of the existing softcode.
    at a guess it will currrently be set to 05442, so in that case you'd just change it to 04442!
    jcb
    Sep 2005
    uk
    4,077
    sorted it with some heavy duty googling
    cheers
    b@stard is out now, can go and MOT it!
    Sep 2011
    Sunny Bangor. N.Wales.
    288
    how did you fix it in the end.... (link)
    2000, A4 2.5Tdi Quattro.
    Tinted, 3600WATTSLoud
    jcb
    Sep 2005
    uk
    4,077
    Ross-Tech: VAG-COM: Audi B5 VAG-COM Info
    change 05 to 04 in soft code.
    works for A6 as well
    Sep 2011
    288
    both my wires had "corroded" out of the pad (the pad's ain't even 1/2 worn) so unplugged it and joined them, then re-plugged it all together :D
  1. Brake Pad Warning Light?
    By K-Dash in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st April 2011, 22:23
  2. Brake pad warning light
    By Agent_Trig in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd March 2011, 11:09
  3. hello need help brake pad warning light on
    By sewell10 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 18th January 2011, 23:16
  4. brake pad warning light
    By avanted in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th October 2008, 00:59
  5. brake pad warning light
    By jays3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th September 2008, 10:22
