Volks AutosMonster Motorsport
Thread: Loss of power
    Jan 2004
    Northern Ireland
    34
    Loss of power
    Just noticed my car does not seem to have as much power recently
    Almost as if the turbo wasn't kicking in
    How can I tell what's wrong ?
    Dermot
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,752
    Re: Loss of power
    Will i diag tell you exactly what is up?
    Cheers.
    madkebab's Avatar
    Dec 2003
    South West
    396
    Re: Loss of power
    Could also be a split boost hose.
    Milton Keynes UK
    248
    Re: Loss of power
    Dermot,
    What model car do you have?
    Petrol or Diesel.
    If it is a Diesel then it could be the MAF sensor. Mine went flat at 3000 RPM. Replaced the sensor and now ok.
    Jim.
    Jan 2004
    Northern Ireland
    34
    Re: Loss of power
    Hi, mate did a diag for me and I got the following errors
    16500 Engine Coolant Temp. Sensor (G62): Implausible Signal
    P0116 35-10 Intermittent
    and
    16518 Oxygen (Lambda) Sensor B1 S1:No Activity
    P0134 35-10 Intermittent
    Could the 16518 be affecting the cut in of the turbo ?
    Anyone ?
    Thanks Dermot
    Jan 2004
    Northern Ireland
    34
    Re: Loss of power
    Hi guys, finally got it sorted
    It ties back to the oil pressure warning I was getting
    I had changed the sensor and the warnings stopped but about 3 weeks after the power loss the warnings started again
    Left it in to be fixed. The oil sieve at the bottom of the sump had clogged
    This starved the turbo of oil and the shaft in the turbo broke
    Everything fixed again, great to have her back
    Dermot
