Monster MotorsportEM Tuning
Results 1 to 8 of 8
    Jan 2012
    Malton
    272
    How difficult is it to fit front discs and pads on a B5 TDi 2.5 v6q?
    I need to replace the discs and pads on my beloved A4. I can do some mechanicing but am not an expert by any means. How demanding is doing this job?
    Tom
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,907
    I'd say fairly streight forwards, so long as you have a decent socket set
    TD5 Land Rover Defender build
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,633
    Rediculously simple.
    Only issue i have ever had was one of the caliper bolts was seized in, and sheared off when i tried to remove it. but the pads didnt look like they had EVER been changed
    Currently rolling in a SKODA!!!
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,920
    One of the most easy DIY jobs you can do. Budget on 2 hours all in. Should be ample to get everything out, do the job, pack up and even a sly cuppa in the middle
    Life begins at 140mph
    www.passionford.com
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    done mine on my 2.4 V6 last week the passenger side was eaiser to take the carrier off.
    a tip leave one side of the old pad on the caliper so you dont damage anything and i used one of those one handed G Clamp to push the piston home. IIRC on mine the carrier bolt was 17mm. better off with 1/2 drive socket.
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,504
    Depends on how good you with are spanners/sockets I guess. Look at a Haynes manual to see how many 'Spanners' are next the task of changing the discs/pads.
    It is an easy job though.
    2002 2.5 V6 Quattro
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    I think I'll need to change the brake fluid though. Don't its changed for a while.
    Jan 2012
    Malton
    272
    ... and the answer is very starightforward, got front discs and pads replaced this morning - A4 now drives much better because it stops on a sixpence. Thanks to all for help and encouragement.
  1. Cheapest place for new front discs & pads on 2.0 TDi??
    By RS_Cosworth in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd July 2010, 17:50
  2. Front discs and pads
    By D8UGF in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th October 2008, 10:43
  3. Front Discs and pads
    By edition in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th March 2008, 11:29
  4. Recommendations for front discs and pads
    By andyhud in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th August 2006, 16:34
  5. Avant Front pads/discs
    By Miller in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st February 2006, 07:10
