EM TuningMonster Motorsport
Results 1 to 20 of 20
    jcb
    Sep 2005
    uk
    4,077
    Now What!!!??? bloody mis-fire
    pulled out of a junction rather exuberantly and about 20 yds down the road engine died!
    started up with misfire on 2 cylinders (not this again I thought, thinking of the broken MAF situation i had that cost me 6 hrs on tha A1!)
    pulled away and as revs rose 4 cyl kicked in.
    doesnt like high load/rev combos and drops a cylinder
    need to VAG it today but not looking forward that!
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,137
    Try popping the connectors of the coils 1 by 1 see if drops a cylinder or stays the same.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,521
    ICM would be a guess, only thing that is connected to more than one cylinder assuming mechanicals check out
    jcb
    Sep 2005
    uk
    4,077
    ICM?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,379
    ignition control module.
    Its on top of the air box.
    TD5 Land Rover Defender build
    jcb
    Sep 2005
    uk
    4,077
    yes I see, googled it.
    only done an engine code search and it was clear
    am about to do a full search when I can find the laptop charge cable
    Apr 2004
    12,521
    It rarely throws a code on the std engine management sadly.
    Aug 2010
    3,137
    Mine didnt when it dropped a coil just popped and swapped to find the bugger lol
    jcb
    Sep 2005
    uk
    4,077
    useless system that can stall the engine and run on half the engine and the ECU thinks its normal!
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Quote Originally Posted by jcb View Post
    Slightly off topic, but why did you choose your username JCB? Keen interest or operator as a job???
    Project RS28 build
    jcb
    Sep 2005
    uk
    4,077
    ha, its a long story!
    I needed a psuedonym for a job I had 15 years ago (think of "James" in the Bangladesh call centre but different!) so I stole the name of a guy I went to school with, initials JC.
    Didnt want to look like I was the second coming of Jesus so I put the B after it!
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Ah right, good idea!
    Thought there was an up and coming yellow respray maybe with the addition of custom rear stabilisers for the Audi! lol
    Would love a shot of a 3CX thou!
    Project RS28 build
    jcb
    Sep 2005
    uk
    4,077
    so it is dropping a cylinder under load or highish revs
    few hundred yards later of driving like miss daisy and it comes back on all four.
    if I can get it up to speed with medium revs and under light load it will come back on all four cyls
    is there a block I can monitor or log with VAGCom to see what the ignition is doing before I start replacing ignition components willy nilly?
    does this sound like an ICM?
    do I buy new? (again)!
    "Stick a V8 in it!"
    15,379
    Doesnt really sound like an ICM, they usually just die and the cylinder simply never fires.
    I presume you've checked all the spark plugs first off?
    If so then get yourself a known good coil and swap them out one by one until you find the culprit.
    If swapping coils round doesnt fix it, then try another ICM.
    jcb
    Sep 2005
    uk
    4,077
    plugs are brand new, coils were checked when the MAF died 2 months ago, could check them again I suppose but the problem is it only ever misfires when giving it large at high revs or high load
    soon as you pull over it stops!
    anyone got an ICM they want to load (possibly sell!) to test that theory?
    "Stick a V8 in it!"
    15,379
    Brand new since the issue started? Or just changed recently?
    I think i have a spare ICM, will have a look in the garage.
    jcb
    Sep 2005
    uk
    4,077
    8 weeks.
    have a new set that I may try
    could really do without shelling out for new coil packs and ICM's
    will swap plugs out and check some coil packs to see if I can pin it down
    cheers
    "Stick a V8 in it!"
    15,379
    Even if you just take the plugs out and check them, rules out the possibility that ones fallen apart or something!
    Aug 2010
    1,540
    wonder if this is oil pressure related?
    as in the relief valve is stuck shut? so when you boot it up to high revs the oil pressure is passing the 70 odd psi the relief valve should limit it too.
    the high pressure jacking the lifters up causing the valves to not be able to shut completely?
    does it do it worse/more from cold/warm than it does when hot?
    jcb
    Sep 2005
    uk
    4,077
    cant say I have noticed a link.
    would say that most times it has happened the car has been running more than 5 mins, but short journeys so may not be fully up to temp in this inclement weather.
    will pull plugs and mess around with coils
    cheers
  1. Strange Mis-fire - AUQ Engine
    By petle91 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th November 2009, 21:55
  2. MIs Fire problem.
    By Steve B in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th February 2009, 21:29
  3. Mis-fire
    By dc240969 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd December 2008, 19:05
  4. Diesel Mis-fire???
    By Markos in forum Diesel forum
    Last Post: 11th January 2008, 13:18
  5. Mis-fire problem
    By wibble111 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th July 2007, 03:58
