Volks AutosChris Nott
Results 1 to 12 of 12
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    577
    Horn upgrade ponderings...
    Whilst delving into the darkest recesses of my shed I found a horn I bought at a car boot years ago for a quid STEBEL S.p.A. - horns
    My question is, can this just be wired straight to the existing horn wires? It comes with a simple relay but I'm not sure if I have to use it or not?
    2000 1.8t quattro Sport totally standard (ish)
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,503
    It should be a very easy wire straight in job, as long as it is a 12v unit. Your Audi most likely will have two horns so just use the wiring from one of them. You shouldn't need to use the relay if you use your existing horn wiring.
    2002 2.5 V6 Quattro
    Aug 2010
    1,540
    hmmm do the instructions tell you how many amps it pulls in operation?
    infact scratch that, what amp relay were you given in the fitting kit? if the factory audi horn relay is the same or higher rated then you dont need the supplied one. just wire it up to wiring to the excisting horn.
    NineNails's Avatar
    Sep 2006
    North Wales
    577
    Relay is rated @ 30A, the horn is rated at less than 18A. Surely a quick blast of the horn now and again isn't going to make anything overheat?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    The two factory horns are presumably also using around 15A each though, hence the 30A fuse and big relay as standard...
    Stick another 18A on top and you'll probably just blow the fuse.
    TD5 Land Rover Defender build
    NineNails's Avatar
    Sep 2006
    North Wales
    577
    Was going to use the Nautilus instead, not as well as Kev.
    "Stick a V8 in it!"
    14,900
    ah fair enough then,
    The car has two horns as standard, one high and one low pitch.
    Find whichever horn is closest in frequency to the new one and swap that out.
    NineNails's Avatar
    Sep 2006
    North Wales
    577
    Cheers, will do. I'll give it a go when the bumper is off for the belts. Just fancy doing it for something a bit different
    NineNails's Avatar
    Sep 2006
    North Wales
    577
    Not had a car with an after-market horn since the twin air horns I had on my Mexico
    "Stick a V8 in it!"
    14,900
    Should just about be able to do it thru the grille if you want it done sooner.
    I want a train horn or similar for mine, something so loud that folk in bus stops jump for cover, but unfortunately they usually require a somewhat substantial air supply.
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Do it Kev....
    Project RS28 build
    NineNails's Avatar
    Sep 2006
    North Wales
    577
    Aye seen similar before. If only I had the money to burn it sure would be a blast!
  1. Horn :/
    By MattyW19 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th June 2011, 18:40
  2. S3 Horn ?
    By L e o in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd April 2010, 19:54
  3. Where's the A8 horn?????
    By axelfols in forum A8/S8 forum
    Last Post: 27th April 2008, 09:09
  4. Got me the horn at last!
    By simch in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th July 2007, 07:22
  5. horn
    By Bellic in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th January 2007, 14:37
