EM TuningChris Nott
    Apr 2006
    A, A
    269
    Slight ticking from engine S4 B5
    It sounds like the exhaust have a slight leak but I don't think it's that. Seems to be coming from the drivers side middle of the cam. The fuel pressure regulator is ticking away s oI woder if it is that but it's hard to listen for anything else when all I can hear is the FPR. Are they generally noisey or just when they're failing?
    Andy
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    Injectors generally tick, but you only typically notice them when your listening closely at the engine.
    TD5 Land Rover Defender build
    Aug 2010
    1,540
    solenoid for the charcoal filter on the fuel tank breather system? these tick when in normal operation.
    May 2010
    Bedford
    2,877
    Especially if the plastic on said valve cracks or snaps off.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    AudiiduA's Avatar
    Midlands
    358
    Fuel pressure reg!!
  1. Ticking from engine bay
    By Blounter in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st January 2011, 16:48
  2. HELP! Ticking noise from engine
    By smudge_don in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th February 2009, 23:04
  3. Engine ticking 2.3 e Coupe
    By donnylad in forum General Technical / How To
    Last Post: 30th August 2006, 01:08
  4. HELP-ticking noise from engine
    By donnylad in forum Classic Audi Forum
    Last Post: 28th August 2006, 21:08
  5. slight ticking on tick-over
    By slimbloke in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th November 2004, 13:11
