AH FabricationsSky Insurance
Results 1 to 16 of 16
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    380
    1.8t Starting issues.
    I recently bought this car with a few issues one of which was a slight starting issue.
    Here is a vid of my issue
    8dc809e8.mp4 - YouTube
    At the end of the vid when the revs rise I blipped the throttle and it roared in to life. the car idles fine also.
    It happens when both warm and cold. I've just swapped out the the cts for a new genuine one which hasn't really helped. The stat needs replacing also but can't see this being related?
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,505
    Crank sensor maybe?
    Have you had it scanned by VCDS/Cag-Com yet? If not, spend less than £10 and get a kit for your laptop and do it.
    2002 2.5 V6 Quattro
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    380
    I haven't yet no. Is it really that cheap to get the software and cable?
    S4_dan's Avatar
    Jan 2006
    1,505
    VAG COM USB DIAGNOSTIC CABLE 409.1 OBD2 II LEAD VAG-COM | eBay
    This is what I have bought and used trouble free. Less than £10.
    Very good service too, I ordered from this guy at 2.30pm and it was through my letterbox by 9.30am next day!
    2002 2.5 V6 Quattro
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    380
    Thanks for the link. I've just bought one, all I have to do now is figure out how to use it :D
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    380
    No error codes found. Well no engine related ones anyway. I'm still thinking its fuel related tbh. Will try changing the plugs as well. Any idea which plugs I need?
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    380
    Just to bump this with a result. My issue is the battery fitted is too small and not putting out full power at that. When trying to start the car the volts drop to 7v and crashing the ecu.
    New batt should sort it
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    577
    I was gonna say do a throttle body alignment. Hope the new batt sorts it
    2000 1.8t quattro Sport totally standard (ish)
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,912
    dunno tbh, the voltage drops fairly low on the missus car, so much so that you can hear it struggle to turn over on cold mornings, yet it never has any oddness and always starts on the button.
    Not sure whats up with hers actually, as the battery itself is fairly new, i guess it must be some crappy wiring somewhere!
    TD5 Land Rover Defender build
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    380
    This is a picture of the current batt which seems too small
    Had it on a batt tester today while the mot was being finished which confirmed that it's duff. On a side not I now know that the alternator is in good condition
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,633
    Jeeeeez, that is tiny!!!
    the one in my 1.8T is at least twice the size. Reccomended Minimum spec is 640CCA (cold cranking amps) and 70Ah (AmpHour). think mine weighs about 20KG too, which i doubt that one will....
    Currently rolling in a SKODA!!!
    "Stick a V8 in it!"
    14,912
    The one on the avant is the same size! Saloons battery is one notch longer.
    Arrkon's Avatar
    Oct 2010
    1,633
    The one on my saloon is just small enough to fit the retainer in the very last hole on the battery bracket (with persuasion) lol.
    Does pay to check the drain holes while your there changing it though....
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    380
    My car still does this. Turns out it wasn't the battery
    Anyone got any other ideas? Fuel filter perhaps?
    "Stick a V8 in it!"
    14,912
    Mine does something similar at random. Sometimes it'll fire right up, other times it does what your video shows.
    I just poke the throttle instinctively now whenever its having an "off" day.
    Interestingly, since the missus car has had its larger MAF and injectors fitted, its started doing it as well. Obviously on hers the MAF calibration on the ECU is out because its not been tuned yet, but maybe that points to a MAF (or other fuelling) issue on yours?
    I wouldnt think its the filter, that would be more of a problem at full load when the demand is the greatest, but it could be gummed up injectors with a poor spray pattern, or ropey spark plugs or similar.
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    380
    I also prod at the accelerator which helps it start when it's having one of its off moments. I need to swap out the plugs soon also although I don't think the issue lies there tbh.
  1. A6 Starting issues
    By dish90 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 27th May 2011, 20:40
  2. Starting issues 2.8 v6
    By Foxmeister in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th December 2010, 11:45
  3. S4 - Starting issues?
    By AndyT_uk in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th August 2010, 13:29
  4. A3 starting issues
    By JustCharlie in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th April 2009, 10:36
  5. S3 starting issues
    By JayMc in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th April 2009, 01:08
