Badger5Chris Nott
Results 1 to 17 of 17
    jcb
    Sep 2005
    uk
    4,077
    No temperature on gauge (dead sensor)?
    If it is dead and has been driven like this is that a problem?
    it seems very hot but the 2nd fan isnt kicking in
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Whats it reading on the hvac ?? Mine displays 30 every now and then when it drops off and also reads 30'c from cold so presuming its the sensor.
    jcb
    Sep 2005
    uk
    4,077
    no reading , needle is unmoved
    (by HVAC I assume you mean gauge?)
    Aug 2010
    3,138
    No a/c control if you press recirc and the up button for vent distribution then go to 49 then press recirc it will give you the actual temperature in digits.
    jcb
    Sep 2005
    uk
    4,077
    they want £33 for a new one!!
    eBay have then for £7. is that a disaster waiting to happen!?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    yeh i'd stick to genuine, speak to Jason.S on here he'll get you some discount.
    TD5 Land Rover Defender build
    jcb
    Sep 2005
    uk
    4,077
    TPS are selling stuff at Audi dealer prices.
    Aug 2010
    3,138
    Theres meyle ones on ebay for about £9 iirc
    jcb
    Sep 2005
    uk
    4,077
    saw those. and some febi ones.
    TBH I do not want this to turn into a money pit
    if the sensor was goosed why would it run hot?
    I assumed it would run cool if anything as I expected the fan to be on permanently.
    Also done a full scan in VAG and no code for ECT sensor....strange?
    Aug 2010
    3,138
    No code here niether aslong as the stat is working and the viscous fan is running id say your ok the electric fan is there as a back up and when the A/C is switched on iirc
    jcb
    Sep 2005
    uk
    4,077
    so its not the sensor or it is the sensor but not an issue to run it like that?
    "Stick a V8 in it!"
    15,385
    Sensor for the fan is totally unrelated to the sensor for the dash.
    The CTS on the back of the head supplies a signal for the guage and a signal for the ECU. If this is faulty you'll have **** economy and probably dodgy emissions as it'll run rich all the time.
    The electric fan is controlled by a 4 pin sensor in the bottom radiator hose, and/or the Aircon controller. The viscous fan should run all the time. If you switch the AC on and the electric fan doesnt start then its faulty/broken/unplugged/blown its fuse...
    Is this the TQS your on about, or something else?
    wallace78's Avatar
    Mar 2012
    belfast
    146
    i didnt get a book with my car how do u put the aircon on iv a funny feeling its not working and were abouts is the sensor in the ingine bay,chees
    "Stick a V8 in it!"
    15,385
    Facelift or Prefacelift?
    Facelift runs the AC all the time unless its below 5c or you press the ECON button.
    Prefacelift has a "frost" symbol on the climate unit to turn on the AC.
    wallace78's Avatar
    Mar 2012
    belfast
    146
    cheers m8 mines the facelift
    Aug 2010
    3,138
    Yeah i couldnt sus that one when i got it so i make sure the econ button is lit up all the time.
    jcb
    Sep 2005
    uk
    4,077
    A6 2.8Q
    but the A6 forum is like a morgue!
    will check the AC
  1. temperature gauge
    By DEMON JAMS in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd March 2009, 19:28
  2. Temperature Gauge on new Astra
    By smee in forum General Chat
    Last Post: 26th March 2007, 23:30
  3. temperature gauge
    By danej in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th June 2006, 07:45
  4. Temperature Gauge
    By imported_topcat28 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st April 2005, 18:38
  5. A3 Temperature Gauge
    By cpt_splash in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd November 2004, 09:05
