JMB RetrofitsChris Nott
Results 1 to 35 of 35
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    Unicorn Motor Developments ME7.x Map Switching feature
    We are pleased to introduce our new totally unique map switching function. This allows for up to 5 different maps to be selected instantly without the use of any additional hardware.
    The driver turns on the ignition, and presses the pedals in a certain combination, which causes the map to be switched. The current map is then displayed on the rev counter to provide feedback. Press the pedals again, and you switch to the next map set.
    Once the engine is started, the rev counter reverts to normal operation. The last selected map is stored so that it is remembered for the next time the engine is started.
    Examples of maps include valet mode, methanol injection tune, Race fuel tune, high boost drag tune.
    Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Sounds good Rick, what can you do with ME5 thou???
    Project RS28 build
    Jan 2012
    Stockport, Cheshire
    748
    We can map it, but no fancy features I'm afraid.
    Rick
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,107
    I want launch control and flat shift when the cars ready for a tune il be popping to you guys as im in oldham, can you provided a chip for k04 hybrid, bigger injectors and maf whats the costs on that and have you 4wd rollers ???
    Jan 2012
    Stockport, Cheshire
    748
    We can only do the launch/flat shift on ME7 cars, what engie code do you have?
    Rick
    Aug 2010
    3,107
    Its ajl
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Quote Originally Posted by Rick @ Unicorn Motor Dev. View Post
    Rick
    Can you do full custom maps??? Its for a PES G2 Supercharger, different injectors, rising rate fuel reg etc. Would like it all done to suit my exact car as PES generic maps are crap aswell as the standard G2 injectors.
    If so, how long, how much and whats involved?
    Project RS28 build
    Jan 2012
    Stockport, Cheshire
    748
    Quote Originally Posted by Bradderz_1988 View Post
    Its ajl
    Unfortunatley that's an older management. We can custom map it, but no launch or flatshift i'm afraid.
    Rick
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,287
    Can always convert to ME7.5 like i'm doing (and marks already done)
    TD5 Land Rover Defender build
    Aug 2010
    3,107
    Whats that involve ??
    "Stick a V8 in it!"
    15,287
    DBW loom, throttle body, ECU, MAF, injectors, Lambda, MAP sensor, throttle pot, some wiring and lots of faff.
    Jan 2012
    Stockport, Cheshire
    748
    Quick video of it in action, not a lot to see apart from the Tacho feedback
    Unicorn Motor Developments ME7 Map Switch example - YouTube
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Quote Originally Posted by Foxmeister View Post
    AHEM!!! Didn't get a reply Rick, and info on this please???????
    P.s I like the vid of the switchable maps, good idea, but i only want what i mentioned above, single map for all driving.
    Project RS28 build
    Jan 2012
    Stockport, Cheshire
    748
    Rising rate fuel reg is very difficult to map for, any reason you are using one? We can msp such a custom setup, but even with a standard fixed differential FPR it is extremely time consuming to get it right due to the time it takes to flash, log tune, flash etc. It would be a minimum of a weeks work and around the £600 mark. We wouldn't let it go until it was right though, providing all the hardware was suitable and working properly.
    Thanks, Rick
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Thanks, Rick
    Yep, it will be time consuming and a week is around the timescale i have already spoke off with Regal Autosport.
    Time is no issue with me thou, just want it done right.
    When speaking to Ryan at Regal, he suggested the rising rate reg due to the design of the SC and the fact the car isnt designed to run a SC at the minute, so will help him get better fuel trims etc and more accurate and is peace of mind for me.
    Regal quoted me around £400ish for the map, with new FPR £120 and fit for £70, does your price inc this also or just for the actual map?
    Can you also send me some details of where you are etc, so far only you and Regal seem up to the task, most have refused or simply dont have the knowledge/tools.
    Cheers, Mick.
    Project RS28 build
    Jan 2012
    Stockport, Cheshire
    748
    Mick,
    our price would be just for the map, and some minor tinkering as required. I actually don't understand the logic of a RR FPR. The whole idea of a vacuum referenced FPR is that you keep the fuel pressure at the injector constant so that you can calibrate only for the injector flow. Rising rates were used in the past for example on speed density cars with no MAF, and MAP sensors which could not detect positive pressure. The rising rate reg would then give the extra fuel.
    As you are using a MAF, this takes care of the extra air for you. You just need to make sure you are using a MAF which isn't going to max out.
    Rick
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,500
    i assume the switchable map can only be done on 1mb ME7.5
    Jan 2012
    Stockport, Cheshire
    748
    Quote Originally Posted by Byzan Photography View Post
    Nope, 512kB ECU's too
    Rick
    Apr 2004
    12,500
    ooo so what about a map with launch and flat shift, then a super UL tune and then a low boost, or is that too much to fit in my 512k ecu,lol
    Rick
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Mick,
    Rick
    As said Rick, only went on the recommendation of what Regal advised, it made sense what he said, but so does what you say???
    Can you PM me some company info then and i will give you a shout to discuss what i have in mind and when etc, cheers.
    Project RS28 build
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    Mark, I believe that would just be two different maps, as I would have thought Rick could map launch and flat shift into both of the super unleaded and low boost maps.... But why would you want that functionality on a low boost map?
    Rick mapped my car recently and the tune was excellent. Will defo be going back again soon!
    Mo power, mo problems
    "Stick a V8 in it!"
    15,287
    I need to get my clutch sorted, then i'll be over to see Rick about getting my AJL ECU mapped for its new turbo!
    Jan 2012
    Stockport, Cheshire
    748
    Not too much, we can do that no problem
    What is your ECU part no?
    Rick
    Apr 2004
    12,500
    Scott,. it would be one with all the tricks, one with all the boost etc, but no tricks and one basic "valet " mode with none if possible, at least that would be the plan
    Quote Originally Posted by Blue_Thunder View Post
    Jan 2012
    Stockport, Cheshire
    748
    Sounds good
    "Stick a V8 in it!"
    15,287
    Interesting point... If you had a valet mode, would the ECU rememeber which mode it was in for subsequent starts, or would it default to map "0" every time.
  28. #27
    Jan 2012
    Stockport, Cheshire
    748
    Kev, read the first post again - does that make it clear? if not I might need to reword?
    Rick
  29. #28
    "Stick a V8 in it!"
    15,287
    I still dont see if it would remember the previous setting.
    Lets say 0 was "normal high boost", 1 was "low boost" and 2 was "valet"
    I can see that you'd turn the ignition on, and press them in a combination to get it to mode 2.
    But then if you turn the ignition off, hand the keys to the garage, and they jump in, will it still be on mode 2, or will it have reverted back to mode 0?
  30. #29
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Going by how Rick worded it, i think the selected map is stored as the selected type for every ignition on/off etc only until the next time you repeat the pedal press sequence to change to another map, so it will stay in Valet regardless of key removal etc.
    Project RS28 build
  31. #30
    "Stick a V8 in it!"
    15,287
    DOH i completely missed that bit, even when i re-read it.
  32. #31
    Jan 2012
    Stockport, Cheshire
    748
    Yea, the last map is stored
    Rick
  33. #32
    Apr 2004
    12,500
    Rick, when you get a sec, PM me with costs and options please mate
    PS ECU number 4B0 906 018 AA
  34. #33
    Jan 2012
    Stockport, Cheshire
    748
    What's the spec on your car?
    Rick
  35. #34
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,742
    This sounds a pretty great product! I think you will be pretty busy with some of the S4/RS4 boys too if they are compatible. Great work still developing new products for these old cars.
    A4 1.8T Quattro
  36. #35
    Jan 2012
    Stockport, Cheshire
    748
    It was all developed on an S4 so no problem there
    Rick
  1. Unicorn Motor Developments ME7.x Map Switching feature
    By Rick @ Unicorn Motor Dev. in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th March 2012, 21:39
  2. Unicorn Motor Developments ME7.x Map Switching feature
    By Rick @ Unicorn Motor Dev. in forum Unicorn Motor Developments
    Last Post: 26th March 2012, 09:58
  3. How To Tell If A ECU Is ME7?
    By A3 T in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd December 2011, 10:51
  4. Storm Developments
    By Bula_82 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th October 2007, 21:26
