tangerinedream
Anyone got any tricks to reduce noise from either wind or road , mine seems to be getting louder but i cant feel any wind around seals??
I think it'll be the window frame/door alignment. The rubber door seals also seem to lose their spring when they get old, so they sort of flatten down.
I will get one up tonight , hard to explain but if u open door i just have a metal channel rivited to top of door opening whereas you will have a rubber seal?
First pic on body of car notthedoor itself its the top seal that runs the lenth of both doors goes behind b pillar
Something like that yh lol got the channel riveted to body but im missing the actual black seal bit
Try rubbing some silicone grease into the seals, it rejuvenates the rubber and makes it more flexible - I've just done the wife's car as part of the 10,000 mile service. If you are really keen, see if you can get some 'icex' - this is excellent for keeping rubber supple, although I suspect it is VERY expensive as we use it at work :thumbsup:
just a quick question, how do you adjust the window frame (as my passenger door is ok) but the top corner of the door has a wind noise when driving.
Can you adjust the window frame i thought they had fixed holes when i was putting my car back togeter but may be wrong?
Im still struglung to find the audi no on etos anyone help
