Volks AutosChris Nott
    Inertiauk's Avatar
    Mar 2011
    529
    S4 Clocks on an A4 B5.5
    Hi,
    As the title suggest I wondered if S4 clocks (98-00) will fit my B5.5 A4 2.8 Quattro (2000)
    My DIS is knackered and there are some cheap S4 clocks available and the are a bit nicer looking, might be worth upgrading rather than getting mine repaired.
    I understand they will need coding to the car but I know someone who does that on Mk4 Golfs, so I presume the process will be the same, he's looked at my clocks and mine are VDO not earlier clocks which he cant work with.
    Thanks.
    Mark
    __________________________________________________ __________________________________________________ _
    Driving a 2004 B6 Audi S4 - Stage 2
    Jul 2007
    London
    3,082
    If the s4 has digital clock just like your a4 then i don't see why not. For some reason the later immo3 will work on immo2 cars but not the other way round but sometimes the immo light will stay on. Some folks do away by blanking the light with tape...If the s4 dash is cheap then give it a try...
    FOR SALE:
    Inertiauk's Avatar
    Mar 2011
    529
    The S4 clock is digital, however my A4 (which is defiantly a facelift inside and out) has the analogue clock.
    Ile just buy a set and see how it goes.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,914
    Wont work if the clocks arent the same, the wiring is different.
    If your car has a digital clock, you'll need to use a digital clock S4 cluster to replace it.
    If your car has an analog clock, you'll need to use an analog S4 cluster.
    You could get into rewiring, but its not streight forward, and requires you to change the sump pan to one with a sensor amongst other things.
    TD5 Land Rover Defender build
    Inertiauk's Avatar
    Mar 2011
    529
    ah right, fair enough.
    Saved me wasting some money thanks.
  1. Replies: 0
    Last Post: 20th December 2011, 20:48
  2. Clocks
    By rob irl tdi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th January 2011, 00:29
  3. S4 Clocks?
    By phoenixv6quattro in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st December 2010, 19:31
  4. A3 and S3 clocks are they the same?
    By garyrmills in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th September 2009, 12:10
  5. S3 clocks
    By Seizure in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th May 2004, 08:35
