Volks AutosAH Fabrications
    Feb 2012
    12
    vag com help asap
    i want to buy a vag com for my 1997 a4 b5 which one do i buy
    MemoScan VAG5053 diagnostic scanner
    vs450 vag scanner on ebay
    VAG COM Diagnostic Fault Code Reader u281
    i just want to turn off service light and find out why my car just cuts out i been told to get the memoscan as it tells you the fault code and what it means and does other things please can you help asap as i need to buy one thanx dan
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,864
    You need the U280 as the U281 is for can vehicles 2004 onwards.
    Heres the one i bought VW/Audi Scanner Code Reader OBD vag U280 engine reset | eBay
    I now have vagcom on my laptop aswell but this still comes in handy as it lives in the glovebox lol
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Feb 2012
    12
    thanx mate is it easy to use
    Aug 2010
    2,864
    Yeah to buttons enter and erase, it turns on when ignition on when you plug it in first is engine (most common one you will use) so you just press enter about four times and that will scan it if you want to scroll to erase,esc or air bag you just Use the erase button as the scroll button dont no why it has erase printed as you just use the other one to do it lol
  1. i need help asap
    By chris1988brown in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th February 2010, 22:31
  2. NEED HELP ASAP
    By Andywilliams1977 in forum General Technical / How To
    Last Post: 31st August 2007, 17:59
  3. REALLY NEED HELP - ASAP
    By jazzyc in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd June 2007, 18:25
