Monster MotorsportChris Nott
Results 1 to 14 of 14
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    391
    Talking New to Audi Ownership! Want to love the car but...
    Hello All I'm Ash,
    I own an A4 B5 Avant Quattro Reg W 2000.
    The lovely car is driving me mad with niggles... Teach me to buy sold as seen.
    It's got a broken ABS ring... no issues shall get it replaced.
    The temp struggles to reach 70 degrees C. I'm assuming Thermostat? Would this also affect the mid 20's miles per gallon I'm getting. Anywhere between 23 to 25!
    A strange knock when I brake, just once, I can't feel it just hear it. Wondering if it could be the ARB bushes? can hear a slight rattle when on rough roads. It handles like a new car as far as I'm concerned! fantastic to drive.
    the Dash is well em like reading through your fingers on the LCD panel lol... I'll get that booked to be repaired in a few months.
    Going to have the cambelt waterpump and thermostat changed tomorrow so hoping that will help with the fuel and piece of mind issue lol.
    I'm also getting a slight electrical whistle via the radio, so I'm assuming it needs suppressing?
    any advice would be great :-)
    thanks,
    Ash
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Temp will be stat.
    Knocking could be either c links on arb, suspension arms/coil spring, driveshaft or cheap pads that are a little to small for the carriers just grease them up and see if it goes.
    Any pics ????
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    391
    Quote Originally Posted by Bradderz_1988 View Post
    Temp will be stat.
    Any pics ????
    Crumbs really! Hope none of that isn't costly lol
    and here she is
    [IMG][/IMG]
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,483
    Hi Ash, welcome to ASN. Lovely car, nice colour. Hope you enjoy the forum.
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    391
    Quote Originally Posted by Sandra View Post
    Thank you I'll try my best :-)
    Aug 2010
    3,138
    The suspension arms arent cheap unless you buy ebay ones but if you do you will only be replacing them again soon !!
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    391
    what we talking £100?
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,088
    Re the radio whine check the earth strap for the coil packs on the cam cover (under plastic cover). Suspension arms can be expensive but don't be tempted to buy cheap.
    Life begins at 140mph
    www.passionford.com
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    391
    Quote Originally Posted by Oranoco View Post
    Thanks for that. Changing the cambelt tomorrow so We'll check all that.
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    391
    I've been pre warned that audi electric prob's could be loosing me MPG other than the thermostat what else can cause fuel usage issue if nothing is coming on warning wise?
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,612
    Coolant Temp Sensor, MAF, Poor condition plugs...Will cause poor mpg. Change the Stat first and CTS if no improvement. (use genuine part only for the CTS! Dealer is about £23 for it)
    A decent set of suspension arms, look for Lemforder or Meyle arms. Expect to pay £300+ for a set (both sides) but they last longer than OEM Parts. Cheapo ebay ones you will be replacing after ~4k miles.
    2002 2.5 V6 Quattro
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    391
    Quote Originally Posted by S4_dan View Post
    Hi Dan,
    thanks for the reply.
    What would you say is more common to cause poor mpg? Plugs? mean spark plugs sir? it'd does drive really well.
    It does idle like it's cold though 3/4 about 900rpm.
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    Bridgend, South Wales
    617
    OEM arms are Lemforder.
    I've had the same suspension arm bought from a VW Main Dealer and EuroCarParts in front of me at the same time for comparison and they were absolutely identical in every way (including Lemforder logo, colour of dust boot cover over balljoint, casting marks etc) except the Euro one quite clearly had had the VW/Audi logo ground off it, came in a plastic bag with mounting bolt/nut and was over £40 cheaper than the 'Genuine' one!
    '99 Ming Blue A4 Avant TDi SE 110 + Dragon Performance Tuning Box
    Factory sunroof / Cruise / Aircon + Climate / Royale Blue leather
    '72 1302LS Karmann Beetle Cabrio Silbermetallic
    '63 Karmann Ghia Sunroof Coupe Pacific Blue
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    391
    Right we're getting there! Stat was shot! new one in running constant 90 degree c and I think the fuel is improving as I can't see the needle dropping anymore lol.
    Now the rattling turned out to be quite funny! it was my brake pads moving in the calipers!. However the edge of the rad is seeping slightly but will be changing that next week with the cambelt, water pump and broken abs ring... once all that is done it's pretty much there.
    Still getting the odd tap noise from the brake pedal, can't feel it just hear it so just wondering if the connector between the pedal and servo is dry... But the suspension is sound :-)
  1. New to Audi ownership
    By box500 in forum The Welcome Section
    Last Post: 5th July 2011, 00:06
  2. Changing Car Ownership Question
    By Wai-Fan in forum General Chat
    Last Post: 26th May 2010, 19:49
  3. I LOVE MY CAR!!!!
    By Davsurfa in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th October 2009, 16:16
  4. Another love it or hate it kinda car BMW Z4M Coupe
    By Gilly in forum The Cool Wall
    Last Post: 25th October 2007, 21:30
  5. New Audi A6 owner..love the car...but.....
    By tristancarroll in forum The Welcome Section
    Last Post: 2nd October 2003, 11:45
