Badger5Sky Insurance
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,606
    ABS coming in at low speeds...
    Hi all,
    I've got the common 'ABS coming in at low speeds as i'm about to stop'
    VCDS hasn't picked up any DTC's as in no sensor failure.
    But is there a way VCDS can detect which sensor it is that is activating the ABS?
    Doing front suspension next week, so could change the reluctor rings then if its the front ones that are causing the problems.
    Cheers,
    Dan
    2002 2.5 V6 Quattro
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,379
    Usually its a broken ring, or a not-quite-fitted-properly ABS sensor.
    Ive seen a few rear rings break, but no fronts yet.
    TD5 Land Rover Defender build
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    http://www.vagcom.co.uk/abs_demo.htm
    ^^^ for some reason once you click the link above you may have to refresh the page to get it to show, dunno why^^^
    2000 1.8t quattro Sport totally standard (ish)
    S4_dan's Avatar
    Jan 2006
    1,606
    Quote Originally Posted by NineNails View Post
    Works fine on my laptop. Cheers for that. will run some tests over the weekend.
    2002 2.5 V6 Quattro
  1. Vibration from engine when turning at low speeds!! HELP!!
    By Mean_Grey_Machine in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th August 2010, 14:03
  2. Rear wheel squeak at low speeds?
    By r3stu in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th June 2010, 18:15
  3. 1.8T stalling at low speeds
    By Crazyfool in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd February 2008, 08:45
  4. ABS keeps kicking in at low speeds? Only since CV boot change tho?
    By Charlies604 in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th January 2006, 13:12
  5. Hunting/surging at low speeds when cold
    By Eeef in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th November 2005, 17:26
