Badger5Volks Autos
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,621
    Front suspension changing.....
    I will be doing the front suspension next Wednesday afternoon in the garage at work.
    How long (roughly) does it take to do one side? I am competent at using tools, plus I will have use of windy gun, pit, heat if needed.
    I have bought a cheap kit (don't shout at me! I know, but as long as it gets me through my mot) off ebay (£43) and came with no bolts. But I have been to me bud at VW and got all the nuts/bolts I need. (So glad I didn't have to pay the £61.80 they should of all been!!)
    Does the leg have to off at all? Or is it a case of just removing and replacing the arms? I've done Pugs, Golfs etc with standard wishbones and one lower ball joint etc, Never an individual arm setup.
    Any pointers would be appreciated to save me time next week.
    Test is on Friday.
    The only things I don't have is the TRE's. But had my car over the pit last week and there is no play in the current ones anyway. Only 1 C link and two upper arms were slack but I'm going to replace them all
    TIA,
    Dan
    2002 2.5 V6 Quattro
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,390
    having to remove the upright will depend entirely on wether the upper pinch bolt plays ball.
    If you can get it out, then you only need to remove the mounting plate and shock.
    If you cant get it out, you'll probably end up removing it and having to drill it out or similar.
    TD5 Land Rover Defender build
    S4_dan's Avatar
    Jan 2006
    1,621
    Ah ok. So if the top bolts does come out, I can replace the top, then do the bottom arms not have to remove the hub bolt, disc, caliper etc?
    Cool, so here is to hoping!!
    2002 2.5 V6 Quattro
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    Bridgend, South Wales
    617
    As aragorn has already mentioned, those top pinch-bolts can be an absolute swine to remove if they haven't been out before......
    Once they are out though give the new bolt and its path through the strut housing a liberal dose of copper-based grease and you'll never have any aggro again.
    It's a really crap design though IMHO.
    '99 Ming Blue A4 Avant TDi SE 110 + Dragon Performance Tuning Box
    Factory sunroof / Cruise / Aircon + Climate / Royale Blue leather
    '72 1302LS Karmann Beetle Cabrio Silbermetallic
    '63 Karmann Ghia Sunroof Coupe Pacific Blue
  1. Changing front bumper!!
    By S3 finatic in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th April 2011, 15:50
  2. Is it really worth it? Changing bushes/suspension etc
    By JD09 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th October 2010, 13:35
  3. What bushes are worth replacing when changing suspension setup?
    By Dansmith in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th September 2010, 15:49
  4. Changing from Sport to SE suspension on A4 Avant B6 2001
    By amanz in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th September 2009, 20:59
  5. Clunk from front suspension, not suspension arms though?........
    By Nessy in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th June 2008, 21:37
