JMB RetrofitsChris Nott
Results 1 to 9 of 9
    Sep 2006
    27
    power steering faults?
    Hi there.
    Recently acquired an A4 1.8 20v. Been great up till about half hour ago.
    Driving home, I lose all power steering. Pop the bonnet and check reservoir and the level is down and bubbling and steaming. Further inspection reveals fluid all over the under tray.
    Do these have a common well known power steering fault? Or will some further investigation be required? Also any reason why the fluid was bubbling and steaming? I'm guessing It's due to the fact I had to drive a further 2 mile to get home lol.
    Many thanks!
    Jay
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    Id bet the previous owner used standard ATF fluid and has screwed the rack seals up. The pipes and connections tend to be pretty good and reliable in my experience
    Aug 2010
    1,540
    take the undertrays off and have a nosey round.
    look at the rack boots see if theyre full of hyd. oil?
    these things are getting older now. a pressure pipe could have corroded thru?
    fingers crossed its not the rack. altho its not hard, i wouldnt describe them as fun to change.
    Sep 2006
    27
    I checked the fluid a few weeks back when I bought it..it didn't seem to have the redtinge normally associated with ATF. Will have to further investigate tomorrow.
    Whats the name of the fluid I need to get?
    Aug 2010
    1,540
    green mineral oil.
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,646
    mine occasionally leaks from the joint on the "cooler", a little bent bit of pipe infront of the rad...
    Currently rolling in a SKODA!!!
    Jan 2011
    Aberdeenshire
    646
    I've had it leak from the cooler to rubber pipe joint too, and also had the metal cooler pipe rub through
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    The fluid you want is called "CHF11S" most factors will carry it.
    I know a lot of folk say ATF is bad, but our Avant has had red fluid (so presumably ATF) in it since we baught it two years ago (i didnt notice!) I've recently changed it out for the proper stuff, but touch wood the rack seems fine.
    Both my "shed" and craigs S4 also had red fluid in them and again this was only noticed when draining them down rather than because the rack had started leaking.
    TD5 Land Rover Defender build
    Sep 2006
    27
    Just to update, it was the rack to cooler return pipe. Had rubbed through on the engine bay.
  1. Two faults: knock sensor & Camshaft intake? Heelp....down on power too :-(
    By s3mad_dude in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th January 2012, 20:45
  2. Power steering fluid leak - anyone used Lucas power steering fluid leak stop?
    By DodgeT in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th October 2011, 19:27
  3. Power steering
    By AU01 A4 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd May 2011, 11:21
  4. Power Steering and Steering Lock
    By S3Sport_Guy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th April 2010, 21:20
  5. power steering
    By djb83 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th February 2010, 18:40
