Results 1 to 11 of 11
    Mar 2012
    Perth ecosse
    A4 Automatic gearbox
    Is there any maintainence involved with these?
    When my car is cold, if i select 1,2,3 or D and press throttle to pull away, it will hesitate, sit there rock back and forward but eventually go after about two minutes of part throttle.
    This must reduce fuel economy in some way, and not very good for the turbo surely?
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,021
    Get it down to a gear box garage and get them to replace the oil and strainer (filter).
    Made a huge difference to mine.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Apr 2006
    A, A
    269
    You find that just an oil change on an auto box makes it feel like new again.
    Mar 2012
    Perth ecosse
    wondering where the strainer is on these boxes as ScottB5 above mentioned should be changed?
    I have found the filler neck its down beside the oil filter.
    Mar 2012
    Perth ecosse
    anyone?
    Mar 2012
    Perth ecosse
    bump
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,388
    Get yourself a workshop manual. Either a haynes, or a copy of ELSAWin from ebay. They're invaluable when starting out maintaining a new car.
    TD5 Land Rover Defender build
    Mar 2012
    Perth ecosse
    Had a leaking gearbox oil cooler at the weekend.
    fixed that and refilled the box with atf.
    Still the same symptoms as first post. can anyone tell me if this is normal?
    Mar 2012
    Perth ecosse
    Anyone?
    does the torque convertor begin to play up at all?
    It goes fine in reverse, im presuming this is a friction clutch though
    Mar 2012
    Perth ecosse
    BUMP
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,021
    I got no idea.
    i think we are the only two people with auto boxes in the B5 sections. lol
    i have heard of torque converters failing.
    i missed the question about the strainer, get it replaced with the oil.
  1. A3 Automatic Gearbox electrical problems
    By Slymiloni in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st January 2011, 10:22
  2. Automatic gearbox cooler/radiator
    By rhinopower in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st January 2011, 17:18
  3. Automatic Gearbox
    By colinra in forum General Chat
    Last Post: 24th December 2008, 20:28
  4. Automatic gearbox issue
    By pmdk in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st June 2008, 15:20
  5. Top up oil on Automatic A3 gearbox?
    By nicelad_uk in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2008, 21:20
