JMB RetrofitsVolks Autos
Results 1 to 24 of 24
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    406
    Oil/water temp gauges not moving on 1.8t a4 quattro
    The oil and water temp gauges on my a4 1.8t quattro sport have stopped working. Is this a common issue? I have had a quick search but can not find the answer so sorry if it's been covered many times before.
    The car is also hesitant to start when warm after a drive and I wonder if the two are related?
    The average mpg has dropped down in to the mid 20's also which although the car is new to me seems a little poor.
    If anyone can help with any of the above issues I will be massively grateful
    jonnycraig's Avatar
    Jun 2009
    Port Talbot
    158
    VAGCOM/VCDS is a good place to start, maybe someone on the forum lives near you to scan your car for you.
    1996 A4 B5
    1.9TDI SE
    Gone but not forgotten
    Audi A4 2.5TDI Quattro
    Skoda Octavia 1.9SDI (Wont be missed lol)
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    406
    I've heard of this but not 100% sure what's involved. Guess it's just plugging a laptop in to the car?
    If someone lives in somerset who is able to help or can advise a good local garage that won't rip me off that would be fantastic
    jonnycraig's Avatar
    Jun 2009
    Port Talbot
    158
    There are many people on here with much more expertise than me but, yep it really is as easy as plugging a 'usb to audi' cable into a laptop running (very limited but free) software to give a basic list of any problem codes which you can search google to find out what they mean or ask on here. The leads are cheap off ebay £20 max.
    1996 A4 B5
    1.9TDI SE
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    406
    Sounds like a worthwhile investment then. Thanks for the tips. I'm a complete noob to VAG cars. I come mostly from a nissan background.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    the 2 have different sensors, so unlikey the faults are related. What stopped working first? When it was working, did it heat up to 90 degrees on both gauges?
    I'd start with replacing the CTS ( coolant Temp Sensor) as they are cheap and regularily fail, this tells lies to the ECU in regartds to temps, so it has no idea whether to warm srat or cold start. Also if its running on "Half choke" it will affect MPG
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    406
    Not sure which failed first tbh as I only picked it up a few hours ago. I know the previous owner so will ask him.
    The boost doesn't come in until 3.5k either so I thought I may have a boost leak somewhere also
    will I have to pay a visit to the main dealer for a sensor or are they available elsewhere?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    CTS or Thermostat is where i'd be looking.
    TD5 Land Rover Defender build
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    406
    Will try the cts first as I guess this will be the easiest to replace. Where is good place for parts?
    "Stick a V8 in it!"
    15,385
    The dealer for a CTS, i wouldnt use an aftermarket one.
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    406
    Definitely don't want an aftermarket one, was wondering if their is a cheaper supplier than going to an audi main dealer?
    jamie226bhp's Avatar
    Aug 2009
    464
    Only about £24 from dealer and that's full retail price
    2000 A4 1.8 tqs scroll sp51, ths decat, milltek cat back with rs4 backbox, remap
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    406
    Fantastic, hopefully a simple fix then .
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    406
    Another proper noob question but is their a guide anywhere on how to replace the cts? I have no idea where it is or what it looks like :o
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    IIRC its at the back of the engine and on the tqs its a blue 4 pin connector and just has a push-fit clip holding it in place.
    audiv6quattro's Avatar
    Dec 2010
    East sussex
    392
    Yep cts is back of the engine, drivers side or at least on mine it is but Audi wanted £55 for a cts for my car.
    1996 A4 2.6 v6 quattro,love the car hate the cost!!
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    406
    I'll ask in my local dealers on wednesday as i'm off work. Whats the deal with the ebay ones that have a 12 month warranty? Guess they are the normal ebay rubbish.
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    406
    I've now replaced my CTS which has made the gauge start working again :D The temp only gets up to 90oc when idling and ~80oc while cruising. I'm guessing i'll need to look at the stat also? The car now drives much better though and almost seems to be less laggy??
    I was hoping the new sensor would cure my rough start problems but they remain
    Here is a vid of my issue
    8dc809e8.mp4 - YouTube
    Can't seem to embed videos for some reason
    At the end where it almost stalled I gave it a little throttle and it roared in to life. Could this be fuel pressure related?
    Dec 2010
    East sussex
    392
    Temp should be at 90 mate that's normal any higher then I'd be worried, mine drops a bit when on motorway cruising aswell
    "Stick a V8 in it!"
    15,385
    Your temp shouldnt move from 90. The guage has an internal buffer such that all "normal" operational temps will display 90. It only moves down from 90 if the temp drops below around 80c. If its moving around like that, your thermostat is faulty.
    Did you use a genuine Audi CTS?
    Mine does something similar on startup and i also changed the CTS trying to cure it, to no avail.
    Maybe not quite as bad as yours and definately not every time, but now and then it'll sort of half catch and mess around about 500rpm. If left alone when it does it, it will (at random) either stall or slowly right itself to 850rpm. If i dab the throttle when it does it, it'll rev up perfectly then drop to a nice idle just like yours does.
    I'd have suggested an airleak or split hose somewhere, but i cant find one on mine either!
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    406
    Thanks for your reply. I'll look at replacing the stat as well then. I got the cts from Audi as I had a search on here and realised the cheap ones are a false economy
    Edit: Does yours throw up any error codes at all?
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    Mine had similar issues with the idle until I did a proper throttle body adaptation which sorted it right out. Might not be your problem but thought it worth mentioning
    2000 1.8t quattro Sport totally standard (ish)
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    406
    It idles fine once started so I think this may be a different issue. Worth looking at in time though I guess It's just the start up which is the issue
    "Stick a V8 in it!"
    15,385
    Yeh mines exactly the same, only does it on start up on the odd occasion. No fault codes.
  1. 2.5 TDi Quattro Oil & Water Temp reading - Possible thermostat prob.
    By fishr in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 3rd December 2012, 13:26
  2. Gauges not moving
    By tombad in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th March 2011, 11:09
  3. Oil temp gauges
    By waring192 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th January 2010, 08:02
  4. Oil dipstick guide..and water temp sensor
    By Custard in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th December 2009, 18:47
  5. Oil temp guage - moving around ??
    By roydonaldson in forum TT/TT-S/TT-RS Forum
    Last Post: 5th August 2008, 16:29
