JMB RetrofitsVolks Autos
    king84's Avatar
    Spartacus
    Dec 2011
    Seattle, WA
    10
    Angry Operation Death To DRL on 97 A4 B5......Fail.
    So..... after researching into how to disable the Daytime Running Lights feature on my 97 Quattro, I had the pleasure in discovering the relay switch that i was suppose to deal with (#204 or #209) had two more of the same one, so instead of just one 204 I found three. Tried putting in a jumper as instructed... BUT... None of them had anything to do with the DRL. I figured out which one it was by turning the key. Once the headlights turned on, you can hear a click sound from a relay. I didn't expect the DRL to be connected into #387.
    Can ANYONE HELP!!!!????
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,651
    ETKA shows part number 8D0 951 293 A or 443 951 293 A to be the DRL relay, but doesnt say what position its in unfortunately.
    Could check the relays you have to see if you can find one with that part number on it?
    Currently rolling in a SKODA!!!
    king84's Avatar
    Spartacus
    Dec 2011
    Seattle, WA
    10
    UPDATE on past failed OPERATION DEATH TO DRL......... Looking back to the prior pic........ I forgot to investigate the red cable that wasn't routed together with all the other wires..... well....... [look below] \/
    That was the culprit. The wiring job wasn't professional and they tried splicing it. All I had to do was cut it and unbolt the other end.....and BAM... No more DRL's. So...... Operation Death To DRL was a success........a few weeks later.
  1. Operation A3
    By jasonallen in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st May 2012, 20:33
  2. Operation German Missle
    By INA in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st February 2012, 10:10
  3. MY OPERATION TOMORROW im nervous.
    By shanejess in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th February 2011, 22:56
  4. Throttle Body - Operation
    By Kevint in forum General Technical / How To
    Last Post: 15th August 2005, 22:36
