Results 1 to 21 of 21
Like Tree4Likes
  • 1 Post By aragorn
  • 2 Post By aragorn
  • 1 Post By Mackers
Thread: Anti Roll Bar Link Bushes.
    Sep 2011
    Sunny Bangor. N.Wales.
    288
    Question Anti Roll Bar Link Bushes.
    hi all,
    i'm looking at replacing my ARB bushes and ARB link bushes on my A4 2.5Tdi Quatt,
    only thing is, i've measured the front anitroll bar at 26MM (not 25 or 27 as listed in the powerflex site),
    is there a sure way of finding out the size and also the size of the rear.
    Many Thanks
    Wayne.
    2000, A4 2.5Tdi Quattro.
    Tinted, 3600WATTSLoud
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    AFAIK all B5 Quattros have a 29mm front and 15mm rear bar.
    TD5 Land Rover Defender build
    Aug 2010
    1,540
    why are you replacing the arb mounting bushes? these dont wear out. ive never replaced any.
    the tiny buses in the "c" links do wear out, but they are cheap and have NO give in new standard ones, so no point replacing with poly.
    apart from the "c" links, if your trying to get to the bottom of a knocking noise...... its not the arb itself!
    "Stick a V8 in it!"
    15,385
    I've never replaced one on a B5, but i have heard of folk over on the 8L forum who have had those bushes wear out.
    Making the mountings stiffer by using poly also increases the effectiveness of the bar, as the squidge when the ARB twists in the rubber bushings reduces the spring rate.
    Also, the standard C link bushes, even when new, do have a fair mount of give. Simply jacking up one corner of the car, and looking at how much the rubber has twisted inside the C links is a good example of this. Again, making it more solid makes the bar more effective, and makes things tighter, as you dont have this two stage effect where an action on the ARB first twists the rubber THEN the steel.
    Sep 2011
    288
    are you sure 29mm, as i have measured smaller, or are the bars smaller at the end (can be seen from the wheel arch, as that's where i measured whilst the car was on full lock :S :S) i'd be replacing the "C" link bar bushes too, as well as the link, i want to stiffen the ride, as after having an MX5, my current car "rolls like a boat" LoL.
    What can i do about the links of the back end ??
    Sep 2011
    288
    ... jus to add there is no knocking either, i want to stiffen the rde up.
    Sep 2011
    288
    Front anti roll bar Audi A4 B5 / Passat B5 8D0411309K New genuine Audi part | eBay
    having used the compatability system at the bottom, it lists my car as having a 26.8MM
    do either of you know if this is right, as i don't want to order the wrong parts, part strip the car, then have to basically do the job twice.
    also does the "back end" have a similar setup to the "C" link setup on the back???
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Its drop links on the rear with ball joint fixings iirc
    "Stick a V8 in it!"
    15,385
    Neuspeed 19mm rear bar with metal droplinks will sort things out nicely when coupled with a sport front bar.
    ETKA definately says 29mm for ALL A4 quattros, there are two part numbers though, i believe cars with sport suspension got a solid 29mm bar and cars with non-sport got a hollow 29mm bar.
    Might want to check your suspension PR code to see if its sport or standard. It'll be 1B? where the ? tells you the type. I believe 1BE, 1BD, 1BV and 1BQ are sport, others are standard.
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,612
    My Quattro has a HUGE red ARB at the front and a thin black one at the rear.
    I will get under car again soon and measure it but it felt solid when i tapped it with a hammer. Wonder why its red though? I'm fairly certain my car has been lowered and stiffened as its handles so much better than my S4 ever did.
    2002 2.5 V6 Quattro
    "Stick a V8 in it!"
    15,385
    Red is something aftermarket.
    TBH, adding more front ARB to these cars just makes them understeer more. Theres good reason Audi fitted the same front ARB to all its sport models from the 1.8T thru to the RS4...
    Hence my suggestion above of retaining the standard front bar, and fitting a 19mm rear bar.
    BRILLO likes this.
    S4_dan's Avatar
    Jan 2006
    1,612
    Never had understeer on mine. Even on tight bends at speed it just clung to the tarmac and goes round. Unless it is still 29mm but an aftermarket item?
    2002 2.5 V6 Quattro
    "Stick a V8 in it!"
    15,385
    Your not driving fast enough then :P
    S4_dan and Mackers like this.
    Sep 2011
    288
    i've got 1BE (sports, i've read on a de-coder thing online)
    my chassis is
    WAUZZZ8D1A0995028D5049,
    i've checked it again and deffo have 26-27MM :S :S so so confused now
    BRILLO likes this.
    jcb
    Sep 2005
    uk
    4,077
    I have solid front arb C links on mine.
    rose jointed alloy goodness originally made for Subaru Impreza rear Arbs.
    they were a impulse purchase but having seen two previous sets of C links shed their inner rubber I have yet to see any issue with these.
    The RS4 boys said the rose joints would corrode away to nothing but 4 years of scotlands finest grit and solt havent had much effect on them at all
    May 2010
    Bedford
    2,877
    The bushes are always smaller than the actual bar on ETKA on the B5. So 25mm for 27mm bar, 27mm bush for 29mm bar.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    Nez
    Dec 2008
    London
    595
    Quote Originally Posted by Mackers View Post
    hi all,
    Many Thanks
    Wayne.
    Hi mate,
    I am selling my brand-new Powerflex Rear Anti Roll Bar Bushes for Audi A4/S4/RS4 15mm
    £25 let me know if you need it.
    (Audi S4 351.9 PS, 603 Nm, MRC Custom Remap XS Power DP's, Cat Back Exhaust, Forge DV, RS4 Intercoolers, RS4 Breaks and Induction kit)
    Traffic Exchange Site http://www.limehits4u.com/
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    Was going to make a new thread but just read through this one and it seemed appropriate so... I don't want to hijack but what would the effects of worn anti roll bar drop links on the rear be? Ta
    2000 1.8t quattro Sport totally standard (ish)
    Sep 2011
    288
    having re-checked with another set of venier calipers (spelling) i can now confirm they are actually 29MM, my guage was 2 and a bit MM out **PHEW**
    as for the offer on the rear bushes... can you pls PM me NEz, i'm very interested.
    Sep 2012
    I have never changed my ARB bushes and ARB link bushes. Actually i did not find i need of replacing them so i am not assure of the way of measuring size of ARB bushes.
    CraigG's Avatar
    May 2008
    188
    you want to be upgrading the rear ARB, so the 15mm bushes wont be any good.
    get a 19mm Nuespeed rear bar and everything will be rosy!
    Imola S4 - Bilstein B6 + Eibach Prokit, Anthracite BBS Pescara 18x7.5"
  1. Anti roll bar bushes????
    By dplovin in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2011, 16:37
  2. anti roll bar bushes
    By S3featesV9 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th April 2011, 16:20
  3. anti roll bar bushes
    By andy999 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th October 2010, 17:19
  4. Anti Roll Bar Link Fitting
    By cheekeemonkey in forum Handling
    Last Post: 25th August 2009, 22:36
  5. Anti Roll Bar and Bushes
    By V6 Quatt in forum Parts Requests
    Last Post: 9th June 2009, 23:01
