Badger5Volks Autos
Results 1 to 14 of 14
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,115
    Another Fault code.
    Right car seams to be running fine noticed last couple of days that the temp gauge drops right of to 60 after being on motorway when it's just been on 90 (didn't see it slowly drop off think it just goes straight to 60) and then I pull up turn engine off switch ignition on and off a few times then the temp suddenly reads 90. I'm I right in thinking temp sensor is goosed ?? Fault code I'm getting is 00561 mixture adaptation regulation.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,324
    Thermostat will be causing the wonky temp, mine did exactly the same. It jumps back up after being parked for a minute due to heatsoak.
    I found with mine that driving slow again, or even pulling into a services and leaving the engine running would bring it back up to 90 pretty quickly.
    Your fault code is unrelated IMO. It probably indicates an airleak, as its the additive mixture thats exceeding the adjustment limits.
    See here for some other possible reasons:
    00561 - Ross-Tech Wiki
    TD5 Land Rover Defender build
    Aug 2010
    3,115
    Already done thermostat not to long ago.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,968
    What does it say on the HVAC?
    Same as what you get on the clocks?
    I got a spare Green plug sensor if its any use to you.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Aug 2010
    3,115
    How do you do the HVAC ??
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,968
    Quote Originally Posted by Bradderz_1988 View Post
    Fan up and recirculate button.
    The screen should go bright and have 01c on the screen.
    Use the up arrow to go to 49 and press recirculate button again.
    Aug 2010
    3,115
    Temp gauge on 90 HVAC says 87 ?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,968
    Thats bout normal.
    There is a couple of degrees difference on mine as well.
    Aug 2010
    3,115
    I'll try it when the gauge drops off see what I get, I used a genuine thermostat when I replaced the old one.
    Aug 2010
    3,115
    Well had a look today and found one of turbo to manifold stud nuts loose before lambda sensor so going to clear fault and see how she goes.
    Aug 2010
    3,115
    Well after being on motorway this morning temp dropped off again and was reading on hvac 30'c so i presume the temp sensor is fubar
    "Stick a V8 in it!"
    15,324
    Not neccesarily?
    Still sounds typical of a thermostat fault to me. What you need to do is get the 49c output up on the display, then drive and see if it moves sensibly.
    If it drops from 90c to 30c in 4 seconds, its probably the sensor. If the slowly and steadily drops at motorway speeds, then slowly and steadily climbs again once off the motorway, then its the stat.
    Aug 2010
    3,115
    Well yesterday it dropped to 30'c and stayed there till i got home and didnt jump to 90 when i flicked ignition off and on a few times, so this morning i checked on the hvac before starting and it read 30'c ??? I would of thought it should be 0c ??? can some one check there TQS and see what it reads from cold please ?? Doesnt do all the time as it did it this morning and not on way home its got a mind off its own.
    "Stick a V8 in it!"
    15,324
    That sounds like CTS then!
  1. I got a fault code - help please. Code 18057.
    By DJ_Troopa in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2011, 10:29
  2. Replies: 2
    Last Post: 19th December 2010, 20:41
  3. Replies: 5
    Last Post: 18th January 2010, 23:36
  4. i just got this fault code..
    By ALPINE in forum VCDS (formerly VAG-COM) forum
    Last Post: 8th July 2008, 15:40
  5. fault code help
    By vw754 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th June 2007, 23:43
