Sky InsuranceJMB Retrofits
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    Soft Touch Boot Switch
    Yet another little problem to pick your brains with chaps.
    One of the micro switches on the boot lid has failed closed circuit (although it still clicks when pressed) so it cycles the boot lock constantly untill I disconnected it.
    My question is... Is there a separate part number for these micro switches or does it come as part of the button assembly? It's only a small micro switch and I'm sure there must be an suitable switch available from Maplins or such like. Anyone ever replaced one of these before??
    Cheers for reading
    Si.
    2000 1.8t quattro Sport totally standard (ish)
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,423
    i got the full part for 38 quid from audi
    NineNails's Avatar
    Sep 2006
    North Wales
    579
    I managed to repair this in the end with a microswitch from an old computer mouse. It was a real BIG pain to do but it works. I'd never try it again though, so much easier to just get a new one lol
    TDiTom
    Ive just semi repaired this on my A3.
    Basicly the washer jet had proken inside the wiper moter, and water had corroded the switches. One side still works, so i just removed and insulated the other sides wires untill I get around to replacing it. You might find only one of them is causing problems.
    NineNails's Avatar
    Sep 2006
    North Wales
    579
    Yes, it was just the off side one. It was disconnected for about a year before I got round to fixing it! Hehehe
  1. Where is the boot light switch?
    By Allen in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st December 2010, 22:07
  2. S4 boot switch
    By S4twiggy in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th October 2009, 20:32
  3. Boot switch failure
    By S3quatt in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2009, 22:02
  4. Audi A4 Boot lock touch pad / unlock button fix
    By Mr K in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th February 2008, 00:26
  5. S3 Boot light switch
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st January 2004, 10:28
