AH FabricationsVolks Autos
Results 1 to 22 of 22
    audiv6quattro's Avatar
    Dec 2010
    East sussex
    392
    Engine code ????
    Hi all i allways thought my a4 2.6 v6 quattro late 1996 has engine code abc but I'm just ordering some new parts and they have asked me if it's engine code abc or acz how can I find out, there is no sticker in the boot? What are the difference between these two engines and can the code be found on the engine itself somewhere. Thanks guys
    1996 A4 2.6 v6 quattro,love the car hate the cost!!
    slepy's Avatar
    Sep 2009
    Sheffield
    1,129
    Don't you have an engine number on your V5?
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    There should be a sticker in the spare wheel well,or on the engine somewhere,or as said,look on your V5.
    hth
    tony
    Dec 2010
    East sussex
    392
    Not too sure mate will check when I get home tonight
    gary3306's Avatar
    Oct 2010
    Northumberland
    950
    The same sticker that is in the boot will also be (or should be) in the front cover of the service book.
    A4 S-Line. Mods so far; Cruise, DIS, Mk2 RNS-e, Audi 6 CD changer, XcarLink with self manufactured permanent ipod dock, B8 MFSW, Dectane Dayline Headlights with independantly switched DRL's, RS4 Rear ARB, De-badged, RS4 pedals, HIDS, RS4 front grille and RS4 style fog surrounds, LCR splitter in Satin Black, Rear Park Assist, LED gearknob, Red footwell lighting, Kitchen sink and Shower cubicle.
    Dec 2010
    East sussex
    392
    There's no sticker in the spare wheel well but will check v5 when I get home
    Aug 2010
    1,540
    should be abc/acz its the 12v engine. i think the abc was fitted in the a4 around 94 to when the a4 was facelifted in 97-98. acz was fitted in much lesser numbers but i dont know why or what the differences are.....
    acz is all but the same as the abc from what i understand, what parts are you after?
    have a nosey on here?
    12v Pages - Home
    Dec 2010
    East sussex
    392
    Cheers murran I'm after drivers side manifold and icv, just ordered 2 lambda sensors, indicator stalk and coolant temp sensor. Cheers again
    Aug 2010
    1,540
    ive just refurbed both heads on my 2.8 ahh lump.
    thing all 12v v6 2.6/2.8 exhaust manifolds are one and the same.
    what does you icv look like? probably the same as any other 12v engine. abit cylider shaped thing bolted to the inlet manifold to the left of the throttle body?
    all these 12v lumps share the same components pretty much.
    damn good engine tho. better than the 30v imo. atleast when im driving mine im not worrying about it dropping a valve!
    Dec 2010
    East sussex
    392
    Nice work funny enough that's the part I'm dreading when it comes to changing the manifold is taking the head, is it possible to just take it of in one piece or possibly not taking the head of at all?? Doubt it, it is an Audi and things are never that easy, yeah icv sounds exactly the same as yours and is just under the throttle body. They are great engines would like a bit more power but can't have it both ways, don't happen to have part number for the manifold do you?? Thanks
    Aug 2010
    1,540
    i took the heads off with the manifolds still on. all but one of the manifold to downpipe studs snapped on undoing the nuts. had to oxy/ceteline them up to remove the broken studs.
    think it wouldnt be "hard" to remove the manifolds without the heads. depends on how rusty and seized the nuts and studs are.
    gary3306's Avatar
    Oct 2010
    Northumberland
    950
    Quote Originally Posted by audiv6quattro View Post
    As I said above...look in the service book!
    Dec 2010
    East sussex
    392
    Hi Gary sorry didnt reply yeah was in the service book thanks it is abc. Been so busy with work ect, cheers mate. Thanks murran, just need to find part number now then its a busy weekend fitting all the new parts, GREAT
    Mar 2011
    suffolk
    249
    If you give us the reg can check on etos/ work for ya
    Dec 2010
    East sussex
    392
    Hi mate it's p139uav, I did put it in my previous post for you to check but you must have missed it, thanks matey
    Mar 2011
    suffolk
    249
    Engine code abc, anything else you need?
    Dec 2010
    East sussex
    392
    Hi mate cheers don't suppose you know the part number for a drivers side manifold??
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Quote Originally Posted by murran View Post
    What do you mean by this? Never heard of the 30v eating valves?
    I was led to believe the 30v were the better engines, not just power but reliability, have you had a 30v that had problems?
    Project RS28 build
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,612
    Quote Originally Posted by Foxmeister View Post
    I've never heard of this either. And with my motor having covered a lowly 173149 miles, it has never dropped one. Neither has the S4 I owned, or the many S4's/RS4's my friends and family have owned.
    I understood that both the 12v and 30v engine were very reliable. (bullet proof as some would say)
    2002 2.5 V6 Quattro
    Aug 2010
    1,540
    in the last 10 years, ive seen about 2 4cyl 20v 1.8t's and 3 30v's (inc one early a6 2.7biturbo) drop inlet valves.
    heads fell off a couple of them but others snapped just below the collets.
    i wouldnt worry unnessasarily, probably just me working in a garage having to fix them, makes me not want to own one, just incase!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,381
    There are probably millions of 20vt and 30v motors in use around the world, and i've certainly never heard of a pandemic style issue with inlet valves.
    Valve failures on 20vt's always seem to be exhaust side as well, as they're two piece things which have been friction welded together due to them being sodium filled. Usually giving out if your revving the engine to 8k or similarly high RPM's on a regular basis, rather than normal use.
    TD5 Land Rover Defender build
    Aug 2010
    1,540
    i agree its hardly a common fault.
    but knowing my luck, if i had one, it would happen to me cus thats just my luck, lol.
  1. 1.8 engine code???
    By James MacConnell in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd February 2012, 18:42
  2. Replies: 4
    Last Post: 2nd March 2011, 12:56
  3. A3 2.0 TDI ENGINE WHEN SWAPING DOES IT HAVE TO BE SAME ENGINE CODE
    By westu_123 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th August 2010, 18:51
  4. what gearbox code matches engine code ASV
    By sjfedex in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th May 2010, 19:18
  5. Engine code
    By Lemon S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th January 2010, 10:14
