Results 1 to 8 of 8
Thread: Radiator Fan
    Aug 2005
    UK, Oxfordshire
    9
    Radiator Fan
    I understand with the A4 that the raditor fan can sometimes come on automatically when the ignition is switched off to cool the engine down.
    Just the other day, mine as started coming on and not going off, so was blowing away all day.... when I turn the ignition it goes off. Came home last night after work and the same problem, eventually flattened the battery
    So just now I have pulled the fuse out for this whilst the car is parked and put it back in when am driving.
    Anyone any ideas, need to take this to the dealer to get looked at?
    M
    imported_VaulterTim
    Re: Radiator Fan
    Thermostat??? Coolant Temp. Sensor???
    Aug 2005
    UK, Oxfordshire
    9
    Re: Radiator Fan
    The temperature gauge displays fine.... no problem at all.
    Should it be a big job to fix ?
    Oct 2004
    Southampton, England
    86
    Re: Radiator Fan
    fan wiring issue
    fault fan control relay
    internal fault with fans
    air con control unit
    lots of possibles
    Mar 2004
    Cheshire
    922
    Re: Radiator Fan
    fault find ... pull the fuse to the aircon (fuse box under panel on end of drivers side dash) when it is doing what you say it is doing, then u know if it is that or something else.
    from memory there are 2 fans, one which is belt driven from the engine and another electrical one which is for cooling the aircon radiator when stationary, so maybe that is your problem?
    Aug 2005
    UK, Oxfordshire
    9
    Re: Radiator Fan
    Thanks...
    will need to see what Audi say... does it have to be fixed by Audi or would I be better off taking it to my local garage etc ?
    Mar 2004
    Cheshire
    922
    Re: Radiator Fan
    local audi specialist as well cheaper!!!
    audi will charge to diagnose the fault (basically checking the computer for the error)
    hop2407's Avatar
    Oct 2004
    Derbyshire
    1,408
    Re: Radiator Fan
    Sorry to hear that matey.... hope it's as they say "All fixed".....
