AH FabricationsBadger5
Results 1 to 7 of 7
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    241
    Handbrake trouble
    Does anybody know how messy a job it is to adjust the handbrake
    mine is stuck off on the drivers side, and won't lock the break on.
    Have my mot tomorrow evening at 4, so going to have a crack at it the morning.
    Big can of wd40 I presume, or is there anything else I need to watch out for
    cheers in anticipation
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,389
    The cables rarely need adjusted, and i'd suggest its somewhat more likely that its the caliper itself.
    TD5 Land Rover Defender build
    Biodiesel Purrrr
    Jun 2011
    London
    150
    is the cable meant to be self-adjusting?
    mine was just on the limit of passing the MOT, apparently.
    -stops the car rolling at the lights but no chance of it locking the wheels!
    TDi Biodiesel sippin' A4 Avant - EGR blanked
    "Cars are good but Jeremy Clarkson is a dick."
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,649
    I "over"adjusted mine up on the ramp, then realised when I tried to move the car... But this was only because the rear pads were royally screwed and had self adjusted down.
    Easy adjustment on a FWD but as Aragorn had said. Shouldn't need doing generally
    Currently rolling in a SKODA!!!
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    241
    Cheers lads, fitted new pads about 2 months ago and all was fine
    going to have a look see this morning and see what's going on
    "Stick a V8 in it!"
    15,389
    Have you adjusted these before?
    The adjusters are fairly fiddly, and are hidden behind the exhaust heatshield.
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    241
    Aragorn you were right, the unit on the caliper was partially bound up.
    Freed it out, but still had to adjust the caliper. All done now.
    On the plus side she passed the mot with flying colours. Yipeeee
  1. 8p handbrake cover
    By chazza55 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd October 2011, 10:58
  2. Help with handbrake
    By droppedaudia4 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 15th July 2010, 20:20
  3. Handbrake help?
    By rossbrownlee in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th January 2010, 10:16
  4. A4 B5 Handbrake
    By Drizz in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd June 2009, 16:51
  5. handbrake
    By jays3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th December 2008, 19:14
