Chris NottBadger5
    Jan 2012
    London
    B5 S4 rough idle
    Hi all, as per title, my S4's still idling rough. I had her put on a diagnostics machine week, which came up with an airbag fault (getting done next week) and a lambda sensor fault. I've have the lambda sensor changed and it has improved alot, but its still rough. Mainly when its settled down to around 8-900 revs. I changed the plugs yesterday to ngk platinum laser ones, and again it feels a little better but still not perfect. Im assuming its an air/vacuum leak i.e maf sensor, but any help is much appreciated.
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    always been like this? is it std?
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    Aug 2010
    1,540
    what bank was the lambda fault on? did you look at the plugs when you changed them? any black/burned out plugs on the same bank?
    might be wise to have a comp test test done. see if anything correlating...........
    Oct 2010
    Ayrshire Scotland
    79
    maybe coolant temp sensor ?
  1. Rough idle really rough
    By audiv6quattro in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th March 2011, 15:33
  2. rough idle
    By s3matthewd in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th March 2011, 13:13
  3. rough idle
    By simon1303 in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th April 2010, 16:24
  4. Rough Idle
    By melman in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th April 2007, 19:29
  5. Rough Idle
    By ad3crk in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th October 2006, 09:52
