Monster MotorsportVolks Autos
Results 1 to 15 of 15
    Biodiesel Purrrr
    Jun 2011
    London
    150
    Brake bleeding - how to?
    been planning to bleed the whole system for a while now but there are a couple of things not mentioned in the Haynes guide:
    -does the A4 have a rear brake balance valve [like on Golfs] that needs clamping open?
    -does the ABS pump need to be set to cycle like on some of the newer Audis?
    also, just to confirm I guess, what wheel would be best to start on -
    Driver side rear?
    Thanks!!
    TDi Biodiesel sippin' A4 Avant - EGR blanked
    "Cars are good but Jeremy Clarkson is a dick."
    kev1000's Avatar
    Jun 2011
    County Cork, Ireland
    194
    Not sure about valve or ABS but I think you start at the furthest away and finish at the nearest to the reservoir.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    I've never had to bleed the ABS, even from a completely drained system.
    TD5 Land Rover Defender build
    Biodiesel Purrrr
    Jun 2011
    London
    150
    I just need to renew fluid - don't think there's any air in the system
    will the pump just flush through?
    my initial thought was the valves inside would be open until the ABS cut in when wheels lock
    "Stick a V8 in it!"
    14,900
    Yeh in that case just ignore the ABS system entirely.
    What i'd do, is carefully remove the reservoir, and allow it to drain into a plastic tub.
    Then refit, fill with fresh fluid and attach eezibleed and pressurise to NO MORE than 10psi.
    This way your not diluting your good fresh fluid down with manky old crap, and keeping it below 10psi should ensure you dont blow up the reservoir.
    Biodiesel Purrrr
    Jun 2011
    London
    150
    Thanks for info, sounds like what I had in mind...
    was going to suck out the old fluid from resevior with big syringe - this is what i did on other cars -
    will that be OK?
    "Stick a V8 in it!"
    14,900
    I think there was some reason that wouldnt work, so i just pulled it off.
    It just sits pushed into two rubber things.
    Biodiesel Purrrr
    Jun 2011
    London
    150
    hang on -
    does the fluid not pour out when the resevoir is removed from the cylinder?
    gary3306's Avatar
    Oct 2010
    Northumberland
    950
    Having been in the trade for over 30 years, I have bled the odd braking system or two. All you need to do is attach a pressure bleeder, them eazibleed things are good enough for what you need. Then start at the furthest wheel away from the master cylinder and crack off the nipple. bleed that caliper for about 15 seconds. Work from the furthest calliper to the nearest calliper to the MC. Once done, start again at the first calliper and bleed all 4 for a second time, then a third time. All the time checking that your eazibleed bottle remains topped up. By the third time of bleeding, you should be seeing lovely new clean and air free fluid coming out. Good luck.
    2012 RNSe Navigation Discs with unit software update. PM me.
    Suzuki GSX-R 750 K5
    A4 S-Line. Mods so far; Cruise, DIS, Mk2 RNS-e, Audi 6 CD changer, XcarLink with self manufactured permanent ipod dock, B8 MFSW, Dectane Dayline Headlights with independantly switched DRL's, RS4 Rear ARB, De-badged, RS4 pedals, HIDS, RS4 front grille and RS4 style fog surrounds, LCR splitter in Satin Black, Rear Park Assist, LED gearknob, Red footwell lighting, Kitchen sink and Shower cubicle.
    "Stick a V8 in it!"
    14,900
    Quote Originally Posted by TeKnodriver View Post
    hang on -
    Yep, be quick, have a tub ready and keep the cap on so theres vacuum inside and you wont spill much! If you do spill any, wash it off immediately with lots of water!
    Feb 2012
    23
    I bled the brakes on my n reg tdi last week. I had to replace the abs pump and my reservoir was cracked so replaced that along with the rubber seals. Handbrake off and started with o/s rear calipar, then n/s front, n/s rear finishing off with the o/s front.
    I bought an easy bleed kit off ebay for about 15 quid and it was spot on but make sure you deflate the spare tyre a little before bleeding else you will crack your reservoir like the previous owner did on mine. Hope this helps
    Biodiesel Purrrr
    Jun 2011
    London
    150
    thank you all for the info...
    had a try today and the resevior was looking like crackle-glaze at the back - never seen that even on older VAG cars
    got scared and ran such a low pressure through the EZbleed it hardly pushed the fluid though
    that and one of the rear bleed nipples was rounded-off... grrr
    will be buying new resevior and doing it properly soon!
    @dubstar - how did you know it needed newe ABS pump?
    Feb 2012
    23
    Basically when i brake and i get to about 10 mph and the brake pedal starts fluttering and the pump would would flash up. I replaced it and it didnt sort it so i put the old one back in.
    I then found out the guy who had the car before me changed all the discs, pads and bottom arms. I think he must of disturbed the abs sensors so i adjusted them. The old reservoir was all crackled up at the back too. The think the guy spent so much money getting the car sorted and then cracked the reservoir on pressure bleeding he just had enough and stuck it on ebay.
    I snapped the car up for a mere £461, replaced reservoir for £45 inc vat from audi, pressure bled it and it works spot on now. I would definetly order new and order a pair of rubber seals too. It is really easy to take off. It simply pops off. I wore goggles just in case. It can get messy. If one of yours rear bleed nipples is seized just make sure you give the opposite side a good bleeding. That is what happened on my old B5.
    spartacus68's Avatar
    Jan 2012
    Aberdeenshire
    54
    Before you start bleeding the system it's worth getting all 4 wheels off the ground. It's a pain otherwise. Last time I did I took around 1.5 litres of brake fluid out of the system until I was satisfied the new fluid was clear and golden. Worth investing in some new brake nipples too. The original ones (thread was corroded) so sometimes they don't tighten sufficiently. I've done it with someone pressing the brake, then moving to the next point. Each time checking the fluid reservoir is topped up.
    Is that with or without VAT?
    2001 B5 A4 2.5 TDI Avant quattro sport (155k)
    2003 A2 1.4 TDI SE (125k)
    1995 80 TDI SE Avant (175k) sold
    Feb 2012
    23
    I have heard some horror stories about manual bleeding on some of the newer cars. It apparently strips the rubber seals within the master cylinder. I bought 5 litre tub of brake fluid in the end from gsf for £24. I reckon i used nearly half bleeding mine.
  1. Brake bleeding - Where can there be air?
    By just017 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th October 2012, 16:57
  2. Brake Bleeding
    By 666markyboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th February 2011, 11:22
  3. Brake bleeding help!
    By swatchuk in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st April 2009, 21:27
  4. Brake Bleeding
    By GSXpress in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th December 2007, 11:56
  5. Brake Bleeding
    By Pat in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th October 2007, 12:49
