Sky InsuranceEM Tuning
Results 1 to 16 of 16
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Heater Matrix Replacement
    Morning people.
    I'm planning on replacing my heater matrix in April and getting all parts ready.
    I'm ordering the heater matrix this week and some coolant.
    Apart from that can any one think of any thing else that needs replacing or recommend replacing?
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Jun 2010
    76
    Going by Haynes it looks like a dash out job!! Good luck if it is.
    a3tdi2001's Avatar
    437
    Are you going for the genuine part from the dealer or TPS to minimise the hassle of doing it all over again further down the line? It's well worth disconnecting the oil cooler pipes and also the thermostat and giving the engine and radiator a right good flush through with a hose to remove any corrosion and also all the old coolant as I feel the matrix rusts from the inside out as the inhibitors in the coolant deplete with time.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Tuffty's
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Quote Originally Posted by a3tdi2001 View Post
    Genuine parts.
    I'm not going through the same hassle as Westy.
    I gave the system a drain and flush through when I replaced thermostat but I will do it again but not to the same extent.
    Aug 2010
    1,540
    its not too bad taking the dash out of one of these. nice job tbh.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Quote Originally Posted by murran View Post
    Im looking forward to it really.
    Get to sort out some wiring and stop the bloody coolant smell.
    Just want to make sure I order all the bits.
    Matrix and G12.
    Next?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    I got most of the bits to do the job this weekend.
    How do you bleed the system again?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,378
    one of the heater hoses has a small hole in it, just pull it back to expose the hole, and fill with water till it comes out the hole.
    TD5 Land Rover Defender build
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    In the bay or cab?
    "Stick a V8 in it!"
    15,378
    Bay!
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Done it.
    Took me a day and half to strip the car, relocated a relay, cleaned up some connections, rerouted some cables, wrapped my last bit of wood trim, replace the matrix and put it all back together again.
    Heres some pics.
    Before I've done any thing.
    Centre console nest of wires. This is what needed tiding up and the location of the relay that I moved where the other relays are.
    Half way.
    No more heater.
    One heater. This thing is huge.
    Just a little leak.
    The end of the day this is what my boot looked like.
    Next day I put it all back together, wrapped the wood trim in matt black. It now looks like this.
    With all the drained out and some spare time I went off and did some engine bay work.
    New EGR blank, Air box cover, New battery cover and new coolant bottle.
    Then a quick clean.
    Its job a I enjoyed, oddly but not one I really want to do again.
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    just about, right here!
    3,755
    well done scotty dog!
    you done good brother! nice to see it all fitted back together and works!
    the strip you wrapped looks the muts nuts mate! i like that a lot!
    now, tell the truth! how many nuts/bolts/screws/fixings were left over? and have you any rattles now?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Quote Originally Posted by CHEZ View Post
    No bolts left over.
    not driven it yet. lol
    I will tomorrow.
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    job well done !
    bay looks mint, i did wonder if you were going to fit that fancy cap to your old manky reservoir
    was blind switch from an a6? could you not fit fog, blank and cup holder from an a6 they'd all sit flush then
    where did you get the matt vinyl i need to cover my shift surround
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Quote Originally Posted by olds_kool View Post
    job well done !
    Cheers mate. I got some other bay bits coming to finish it off.
    also want some plastic dip.
    The blind switch is from a B6. there is company that does a garage opener open for the B5, I might get that.
    I don't like the colour or size of the B6 button but if does the job for now.
    I bought the wrap off eBay.
    You can send me your centre and II'll do it for you or I can send you a section of wrap.
  1. Anyone changed the heater matrix themselves?
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th July 2012, 16:15
  2. A4 heater matrix replacement
    By Miller in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th August 2010, 19:29
  3. Heater Matrix
    By harps21k in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th May 2009, 18:19
  4. Golf Mk2 Heater Matrix!
    By jojo in forum Volkswagen and other VAG
    Last Post: 28th March 2007, 03:51
  5. changinf heater matrix... how?!
    By imported_mattsavage in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st December 2004, 16:47
