Volks AutosSky Insurance
Results 1 to 10 of 10
Thread: WHEEL FITTING
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    241
    WHEEL FITTING
    hi all, i am going to take a look at a set of wheels tommorrow.
    they are 17 inch but the the back is staggered
    front is 225/45 - 17 9j
    back is 225/45 - 17 10j
    the car is a 99 avant.
    should this staggering give much bother to the car overall from a fitting and general running point of view.
    cheers for any advice
    CraigG's Avatar
    May 2008
    188
    225's on a 9" and 10" rim....??
    technically, they are the same rolling radius, because its the same tyres front and back. but those tyres are to narrow for those rims.
    Rim width Minimum tyre width Ideal tyre width Maximum tyre width
    5,0 Inches 155 mm 165 or 175 mm 185 mm
    5,5 Inches 165 mm 175 or 185 mm 195 mm
    6,0 Inches 175 mm 185 or 195 mm 205 mm
    6,5 Inches 185 mm 195 or 205 mm 215 mm
    7,0 Inches 195 mm 205 or 215 mm 225 mm
    7,5 Inches 205 mm 215 or 225 mm 235 mm
    8,0 Inches 215 mm 225 or 235 mm 245 mm
    8,5 Inches 225 mm 235 or 245 mm 255 mm
    9,0 Inches 235 mm 245 or 255 mm 265 mm
    9,5 Inches 245 mm 255 or 265 mm 275 mm
    10,0 Inches 255 mm 265 or 275 mm 285 mm
    10,5 Inches 265 mm 275 or 285 mm 295 mm
    11,0 Inches 275 mm 285 or 295 mm 305 mm
    11,5 Inches 285 mm 295 or 305 mm 315 mm
    12,0 Inches 295 mm 305 or 315 mm 325 mm
    12,5 Inches 305 mm 315 or 325 mm 335 mm
    Imola S4 - Bilstein B6 + Eibach Prokit, Anthracite BBS Pescara 18x7.5"
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,320
    you'll also never fit 9 and 10" rims inside the arches on a normal A4 shell.
    TD5 Land Rover Defender build
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Yanks have fitted 9's with **** poke, stretch and all that crap but i personally think its too much and cant be good for the car/drive!
    10's.......i dont think thats possible seeing as RS boys struggle under their arches!
    Project RS28 build
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    241
    Cheers lads, better give them a miss so.
    floyd 1.8 turbo's Avatar
    Mirror, Signal, Outmanoeuvre
    Apr 2008
    Bracknell, Berks
    630
    A friend of mines running 9x19" Bentley rims with a 3mm spacer on the rear of his B5 S4, it's pretty low on coilovers too and he has no issues
    What wheels were they?., quite unusual for a 17" wheel to be so wide...Porsche rims?????
    White B5 1.8 turbo sport
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    241
    They are almic wiser. 3 piece split rims (a bit like bbs )
    Didnt bother with them and bought a set of 17s from an a4 cabriolet b8
    diffas's Avatar
    Lahti, Finland
    131
    Add diffas on Facebook Visit diffas's Youtube Channel
    There are no problems fitting 9" wheels on A4 with correct ET. With 10" case is not that clear, but still possible.
    Slow and smoking - A4 2.5TDi+ 220+kw
    CraigG's Avatar
    May 2008
    188
    but the point being that you need to run ridiculous stretch on the tyres to get them to fit, and despite what anyone says, stretch to that degree is dangerous.
    diffas's Avatar
    Lahti, Finland
    131
    Nice troll, Craig. :D
    Back to business...
    I looked my setups and looks like 9" wheels with ET37 are fine on front and ET34 rear with the same tire (235/40/18). When using 225/40 tires even ET40 is fine. If you are gonna ride ridiculously low I recommend to use 225 tires.
  1. Fitting Wheel spacers
    By john_cook in forum General Technical / How To
    Last Post: 18th August 2012, 11:51
  2. Fitting 8L S3 steering wheel to a B6
    By Shane-Ireland in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th February 2012, 10:18
  3. Wheel Fitting Enquiry...
    By ScottSummerhayes in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th April 2010, 18:36
  4. Wheel Fitting
    By olivarley in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd January 2009, 23:55
  5. Fitting wheel spacers
    By A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th November 2007, 18:08
