AH FabricationsEM Tuning
Results 1 to 8 of 8
Thread: Downpipe/flexi?
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    Downpipe/flexi?
    Anybody know if they are the same for a FWD 1.8T and a 1.8T quattro? Mine is burst and need a new one. Also can it come out from the top with the cat still bolted to it?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    Quattro one is much shorter than a FWD one.
    I'm not sure if you can simply cut the FWD one down to length though.
    i couldnt get mine out the top, or out the bottom, i had to cut the old downpipe in half with a grinder. Might be different with a ramp though.
    TD5 Land Rover Defender build
    May 2008
    perth
    1,197
    How did you get the new one in?
    "Stick a V8 in it!"
    15,385
    Ah, i was trying to take the cat and downpipe out together, as the bolts that join them were totalled. putting it back together i installed the cat first then the downpipe.
    May 2008
    perth
    1,197
    Yeah. I remember from when i had the engine out those bolts were sell rusted. Thats why i was hoping it would come out together from above. Did you have to go to audi for the new one?
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    If you remove the full air box you can just about pull the full thing from under the bonnet it's a tight squeeze but just clears past and bends the little heat shield on the drivers chassis leg. If your attempting to do it buy splitting it iirc remove the o/s driveshaft heat shield do a bit more room but it's still a tight space.
    "Stick a V8 in it!"
    15,385
    I got mine from Euro Car parts. It was a bit crappy, but it did the job.
    Thinking about it, it was a FWD one i changed, so maybe the extra length caused my problems. The tail of it hit the floor before i could get the angle right to draw it out.
    May 2008
    perth
    1,197
    It's £85+ vat for a new one from Audi so might just go with that. Should last another 200k miles then.
  1. Exhaust flexi
    By OldRedEyes in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th October 2011, 12:42
  2. downpipe/flexi pipe
    By ian52 in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th October 2009, 20:24
  3. CAT / Flexi-pipe
    By QuottroA4 in forum Tuning
    Last Post: 2nd August 2009, 10:26
  4. Flexi size?
    By Soupie69uk in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th February 2007, 21:14
  5. Flexi part on the downpipe.
    Last Post: 15th December 2006, 23:37
