this sort of ****e im about to write is the detail these guides are missing!!!!!!!!!!!
the cams on these dont spring to one side like that. when its timed up theres a natural dead spot.
the cam allignment bar across the front of the engine holds the cams in the correct position.
from memory........
timed up with the crank pin in, with the cambelt all still on, all the covers and aux belt pulleys etc off........ slot the bar in the pins on the diamond shaped bits of metal thats bolted to the front of both cam pulleys (if you cant quite do it cus the cams are slightly out.... this is why you do this procedure!! also it makes it sooooo much easier to put the new cambelt on.) undo the 24mm bolts and undo them say 4 turns at the most. get your puller.
BEARING BUSH GEAR PULLER SET INTERNAL EXTERNAL PULLERS | eBay
something like this....
take the alignment bar back off and slot the legs of the puller thru the pulley and the puller bolt on the center bolt of the cam pulley. tighten it up and the cam will pop off the camshaft and itll now spin freely on the end of the cam but the diamond bits of metal are still fixed in the slots on the cam. now do the other one with the puller.
slot the alignment bar back on to make sure its all lined up still, then take it off again. lever the tension off the tensioner and put the little pin in the damper. finger the bolt out of the o/s cam pulley and drop the cam pulley off.... the belt will now fall off with ease.
do what you have to replacing water pump, tensioner, thermostat etc.
when you come to refit the belt make sure its around the crank pulley correctly and lay it around the n/s cam pulley and water pump, doesnt matter if its taught between the crank and the pulley cus of course it now can freewheel independant of the cam.... lay it around the tensioner. then get the pulley you took off, slot it into the cambelt teeth and put into the end of the cam anywhere you like. put the diamond shaped bit of metal in the cut outs on the end of the cam and finger the bolt back in to withing 2-4ish turns of being tight now slot the bar back on the cams. pull the pin out of the damper let it tension up. leave the bar on to hold the cams and tighten up the n/s cam pulley then the o/s pulley. its 60-65nm.
sounds more work but it really isnt at all!
