EM TuningMonster Motorsport
    Jun 2011
    73
    Thumbs up B5 8D2 Headlight Washer System Project.
    Hi Folks, I recently took my Audi A4 1999 1.8t quattro sport for its MOT the other day, a couple of months ago I fitted some HID Xenon upgrade lights into the dipped beam projector headlights, which give a great looking light being 6000k ice white, chatting with the mot tester he informed me that soon by law you are supposed to have headlamp washers if you have xenon headlights fitted, so I am wondering if any of you guys out there have any suggestions as to how easy or difficult a project like this would be to do - that is to say:
    • are they wired with to work with windscreen washers and is the wiring and switch already there on the stalk ?
    • are they fairly easy to fit into the bumpers and route the tubing to the washer bottle ?
    • are there any additional fuses or relays and wiring looms that I need to fit ?
    • can I obtain the parts from a breaker / does anyone have any parts ?
    • any other important info I might need to know ?
    The car failed the MOT but only on an offside front CV joint gaiter which he is going to do for me monday.
    Thanks guys - look forward to replies
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Just find some one who will pass it without them lol
    Mine has them but I think the pump has packed in going to get a replacement pump, but either way it will pass it always does lol
  1. s3 headlight washer and cap
    By rob irl tdi in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st February 2012, 11:08
  2. Headlight washer problem (07)
    By steve184 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th November 2010, 22:11
  3. Headlight washer repair
    By danger S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd August 2010, 00:36
  4. Headlight washer problem
    By s3mike in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th January 2010, 09:21
  5. Headlight Washer Jets
    By greski in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th April 2004, 13:23
