Volks AutosChris Nott
    gmx
    Feb 2009
    Sydney
    133
    B7 A4 Brakes, which lines?
    So as title for 2.0T/3.2/S4 brakes.
    Are the B5 S4 lines for the Hp2 caliper direct fit and proper length for the B7 A4 calipers or would I have to get the lines or aftermarket equivalent?
    I have goodridge braided SS B5 S4 lines BNIB, hopefully can use them with that pair.
    00 A4 1.8TQS GP MT AJL
    JHM SSK | FX300 + 16lbs FW | Milltek Dump back
    17*8 BBS RK | Deka ETX20L | Vogtland GT 575F/675R | H-Sport 35mm(F)/22.5mm(R) ARBs
    034 Engine Mts | Stern Snub/ Rear Diff Insert/Power Ring
    GT2871R Elim | Custom ME5 | 034 3" DP | 034 HFM | 034 TIP | ER Comp IC
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,287
    All B5 calipers use the same line. They have a small bracket, which is positioned in the same place regardless of the caliper, and then use a hardline from this bracket to the caliper itself.
    The B6 cars use the same system.
    So as long as your B6 calipers come with the bracket and hardline, your good to go.
    TD5 Land Rover Defender build
    gmx
    Feb 2009
    Sydney
    133
    ah ok thanks mate! so length shouldn't be an issue. Come to think of it, probably have a little bit more slack with the B7 A4/S4 calipers over the HP2s.
  1. Brake lines
    By IrishDave in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2011, 16:13
  2. SS brake lines
    Last Post: 29th June 2011, 10:04
  3. Brake lines
    By J B in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2011, 22:15
  4. S3 brakes - brake lines
    By Scott in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd September 2010, 10:02
  5. fuel lines in a s4
    By sharpasadart in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 10th November 2009, 21:06
