JMB RetrofitsChris Nott
Results 1 to 8 of 8
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,751
    Just fitted my K04.
    Hey i just fitted my K04 today took around 4hours.
    The k04 sounds a bit noisier and seems to pull a little better.
    But when the car is spooling up or under load between 2k and 3.5K revs the car cant seem to hold its boost.
    It pulls then stops pulling about a second at a time.
    I havent got and CEL's on and above 3.5K the car pulls really well.
    Any suggestions to this problem would be very helpfull.
    Thanks,
    Paul.
    PS i will post pics in a little while.
    _______________
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    Re: Just fitted my K04.
    have you got it mapped? maybe the wastegate is opening early (total guess)
    what you doing with fpr? keeping stock or upgrading?
    be good to see some pics dude [img]/ubbthreads/images/graemlins/ok.gif[/img]
    btw did you use new turbo drain lines or clean the ones you had? i'm just about to post a thread with this question
    simon_golf_tt's Avatar
    May 2004
    Fife, Scotland
    247
    Paul - That was quick getting the turbo fitted! Nice one.
    Sorry you have a problem. What does it boost to when it hangs?
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,751
    Not too sure what the boost level is.
    I really do need to get a gauge. I am just running it on my Star Performance remap.
    The oil lines i am using are just the standard ones. The one to the sump took ages to refit!!
    I think the actuator is needing screwed back as i think it must be over boosting.
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,751
    Here are some pics of the K04 and old K03s.
    Old K03s
    New K04
    The K04 is about 2mm bigger in diameter. (Inner edge) Also has different blades.
    Both together
    Engine bay with the turbo etc out.
    K03s rear
    Rear close
    K04 rear
    rear close
    The turbine on the K04 is again bigger here.
    Cant really see that well from the pics but the bit in the middle of the turbine is quite a bit bigger which is a good indication of the difference.
    Cheers folks,
    Paul.
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    a mate of mine fitted a N75J to his standard 1.8T and got the same symptoms... The turbo is boosting past the ECU's tolerance. You will need to get the map adjusted to use it.
    Rich
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,751
    So you think i need to get my car mapped as i am just running it on a K03s chip just now.
    The turbo starts spooling up at about 1.5K revs. Thats what made me think the actuator needed adjusting.
    Cheers,
    Paul
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,751
    Spoke to Star and they say that the car is needing a remap however AmD say that it sounds like the Air mass meter has gone as this is a common fault and to get it checked. The car ran fine before the turbo upgrade and only seems to have a problem between 2k and 3.5k.
    I am getting loads of different answers from lots of difference sources and am gtting a bit confused.
    I am pretty skint at the mo and will not beable to afford a remap for about 3 months as i have to get a FMIC first as well.
    Cheers,
    Paul.
