    Feb 2012
    wolverhampton
    Unhappy electrical problem
    Hi there. I have a 98 2.4 v6 b5. Got in the car after not using it for 2 days, and found my wipers, indicators, blower and demiser were not working. Never had a problem before, so have not bump or jump started it. does any one have any ideas of the solution. Have checked fuses (all of them as cannot find a diagram) all are fine. Please let me know. Thanks, Stephen.
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,612
    Hi and welcome.
    I think something very similar happened to someone last year. Do a search using the search function. IIRC it came down to the ignition switch being faulty.
    Dan
    Found the post.............Read this: No indicators, lights, wipers or heating when car is running? But fine on ignition!
    2002 2.5 V6 Quattro
    Feb 2012
    wolverhampton
    Thanks for response. Just tried it but didnt work. Have tried disconecting battery for 20 mins and that didnt work either. Everything else works, hazards, stereo, horn, lights side and main and flash main beam. If you have any other ideas let me know. Thanks Stephen.
    Feb 2012
    wolverhampton
    HELP ME.
    Have had computer link up. These are the results. If anyone has any ideas, please help. am getting desparate. Do not have a lot of money as lost job just after getting car, but need to fix it. HELP.
    Thursday,16,February,2012,19:31:46:40857
    VCDS Version: Release 11.11.2 (x64)
    Data version: 20120126
    Chassis Type: 8D - Audi A4 B5
    Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
    Mileage: 250610km/155721miles
    Address 01: Engine Labels: None
    Part No: 4B0 907 552 C
    Component: 2.4L V6/5V MOTR HS D03
    Coding: 04001
    Shop #: WSC 06335
    VCID: 25446424BFFA27B
    7 Faults Found:
    18010 - Power Supply Terminal 30
    P1602 - 35-10 - Voltage too Low - Intermittent
    17645 - Fuel Injector for Cylinder 1 (N30)
    P1237 - 35-10 - Open Circuit - Intermittent
    17646 - Fuel Injector for Cylinder 2 (N31)
    P1238 - 35-10 - Open Circuit - Intermittent
    17647 - Fuel Injector for Cylinder 3 (N32)
    P1239 - 35-10 - Open Circuit - Intermittent
    17648 - Fuel Injector for Cylinder 4 (N33)
    P1240 - 35-10 - Open Circuit - Intermittent
    17649 - Fuel Injector for Cylinder 5 (N83)
    P1241 - 35-10 - Open Circuit - Intermittent
    17650 - Fuel Injector for Cylinder 6 (N84)
    P1242 - 35-10 - Open Circuit - Intermittent
    Readiness: N/A
    Address 03: ABS Brakes Labels: 8E0-614-111-ABS.lbl
    Part No: 8E0 614 111 AB
    Component: ABS 5.3 FRONT D00
    Shop #: BB 24548
    VCID: 5EB60BC8DA2CB43
    No fault code found.
    Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
    Part No: 8L0 820 043 D
    Component: A4 KLIMAVOLLAUTOMAT_D75
    Coding: 04161
    Shop #: WSC 06335
    VCID: 295C6814D3E203B
    3 Faults Found:
    00792 - A/C Pressure Switch (F129)
    31-00 - Open or Short to Ground
    00532 - Supply Voltage B+
    07-00 - Signal too Low
    01273 - Fresh Air Blower (V2)
    17-10 - Control Difference - Intermittent
    Address 15: Airbags Labels: 8D0-959-655-AI7.lbl
    Part No: 8D0 959 655 L
    Component: Airbag 7 Audi 0503
    Coding: 00104
    Shop #: WSC 06335
    VCID: 3F88D64C3D669DB
    1 Fault Found:
    01217 - Side Airbag Igniter; Driver Side (N199)
    32-10 - Resistance too High - Intermittent
    Address 17: Instruments Labels: 8D0-919-xxx-17.lbl
    Part No: 8D0 919 910 N
    Component: B5-KOMBIINSTR. VDO D02
    Coding: 00462
    Shop #: WSC 00000
    VCID: 3778BE6C1556A5B
    Subsystem 1 - Part No: IMMO
    Component: IDENTNR: AUZ7Z0W0342894
    IMMO-IDENTNR: AUZ7Z0W0342894
    Address 35: Centr. Locks Labels: 8D0-862-257.lbl
    Part No: 8L0 862 257 G
    Component: ZV-Pumpe, DWA, Funk D06
    Coding: 13258
    Shop #: WSC 00815
    VCID: 397CB8542342B3B
    2 Faults Found:
    01368 - Alarm triggered by Luggage Compartment Switch
    35-00 - -
    00956 - Key 2
    09-00 - Adaptation Limit Surpassed
    Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
    Part No: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00101
    Shop #: WSC 06335
    VCID: E0CAB5306058023
    audiv6quattro's Avatar
    Dec 2010
    East sussex
    392
    I had same problem try turning key to start car, as soon as cars started turn key back a couple of mm, don't turn engine of just turn key back a little
    1996 A4 2.6 v6 quattro,love the car hate the cost!!
    Feb 2012
    wolverhampton
    Hi. Took car to an motor electritian today. Found problem. Was a relay, No 177 auxilery contol (something like that). All sorted, apart from interesting prob with wipers. been told it is the motor park switch. They wont always return to the bottom of the windscreen. The bloke charged £40 for diagnosing prob and a tenner for the new relay. Probably took him 10 mins of which 7 was to find the part in his stockroom. Well at least is sorted. Happy days. Car is now for sale if anyone interested. 2.4 v6 30v engine. rear spoiler, sideskirts, 17inch alloys, subwoofer, no rust. Message me . Thanks, Stephen.
  1. 03 s4 electrical problem
    By TURBOTRONICS in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd November 2011, 14:05
  2. Electrical problem
    By 20vtmk3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th January 2011, 23:46
  3. electrical problem please help
    By jay1601 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th August 2010, 20:41
  4. Electrical problem!!
    By little_lockyer in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th October 2009, 13:23
  5. Electrical Problem
    By cooloff in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd October 2007, 08:15
