JMB RetrofitsAH Fabrications
Results 1 to 11 of 11
    Oct 2008
    6
    Paint Lacquer Peeling 02 A4
    Hi, I have an Milano Red (i think) 02 A4 with 110k miles which Ive had from new. A couple of years ago I noticed that the paint Lacquer on the roof had bubbled and started to peel in a few spots, I got this resprayed at my own expense of £300. Recently this has started to happen in numerous places all over the bodywork which looks awful, the guy who does my spraying says he thinks this has been a fault when the car was originally sprayed. The only way to sort this is a full body respray which will be very expensive. Has this happened to anyone else? Do I have a case to take it to Audi to see if they will fix it?
    Mike
    audiv6quattro's Avatar
    Dec 2010
    East sussex
    392
    You can take it to your local audi dealer and show them, cant remember who but someone on here took theres back as the paint work has a 12 year garuntee so give it a go and argue your case, no doubt they will try to get out of doing the work but if it turns out to be a defect then your still covered
    Jul 2007
    770
    Does the guarantee cover the laquer if the paints OK?
    Dec 2010
    East sussex
    392
    Not 100% sure mate cant see why not its still effectively a paint defect i suppose, its a defect caused buy their error when painting the car at the factory, like i say though im not sure.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,391
    Paints only covered for 3 years.
    Quite sneaky on Audis part, as it means half the things that should be covered under the 12 year anti-corrosion warranty get knocked back as being paint defects!
    TD5 Land Rover Defender build
    Oct 2008
    6
    Quote Originally Posted by audiv6quattro View Post
    Does the paintwork not just have a 3 yr guarantee and the 12yr one is for corrosion?
    Jul 2007
    770
    Quote Originally Posted by bigmikeyoyo View Post
    Thats it did you have anything attack the surface eg sap bird droppings ?
    Dec 2010
    East sussex
    392
    Sorry my bad i thought it was paint work covered for 12 years. Sorry for wrong info and thanks aragorn for clearing it up
    Oct 2008
    6
    Quote Originally Posted by Mike B View Post
    No nothing out of the ordinary, cars garaged when not in use. Like I said first the roof and now its the rear nearside quarter panel and boot, both have several patches where the lacquer has bubbled and is peeling off.
    Dec 2011
    Hi I have an 01 Audi A4 in the same colour.
    I have had this problem for the past two years, starts with just a small almost like stone chip size area which grows and flakes, every panel now has a dull area surrounded by cracked lacquer, it will peel and flake round the edges and goes brittle, the car looks a complete mess and allows water underneath which lifts the lacquer and makes it worse? it now needs a complete respray and Audi Derby where useless and very unhelpful, just an Oh Dear, can't understand it? The roof and bonnet are the worst, but now the rar passenger dors have started, and it definitely isn't caused by stone chips or bird droppings?
    Jul 2012
    happend on my rear door but car is a 97, isnt doing it anywhere else
  1. Paint peeling and scratched dash
    By Acidic32 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th November 2009, 11:50
  2. Peeling Lacquer
    By cornishaudi in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 1st November 2009, 10:21
  3. Audi S3 Grill Removal. Primer, Paint, Lacquer
    By Hardsy in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th August 2007, 10:06
  4. Lacquer peeling!!!!
    By dreddg in forum Detailing
    Last Post: 30th August 2006, 13:16
  5. Peeling lacquer on alloys
    By lilya in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd April 2005, 13:17
