EM TuningVolks Autos
Thread: What's This??
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    492
    What's This??
    Found this under the airbox cover on a 1.8t AJL, is it a pressure sensor? looks like it broke and somebody attempted a fix with glue?
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,113
    It's the purge canister Solenoid valve.
    Mines the same and has been repaired with glue and it's not air tight though but at £75 iirc I left it how it was as I will be installing a catch can at some point.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,317
    You dont NEED to fix it, but if you intend on leaving it like that, remove the hose from the other side and block it off so your not drawing in unmetered air.
    Leave the bit thats currently broken open to the atmosphere so the tank can breathe.
    TD5 Land Rover Defender build
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    492
    Cheers Guys.
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,641
    They all break eventually... Mines been left electrically connected so I don't get any fault codes.
    Currently rolling in a SKODA!!!
