Sky InsuranceAH Fabrications
    floyd 1.8 turbo's Avatar
    Mirror, Signal, Outmanoeuvre
    Apr 2008
    Bracknell, Berks
    630
    Question Brake disc center bore size??
    I've got some spacers to fit on the Audi, front and back both sets the same. The fronts go on perfect, sit nice and tight on the disc just as they should. The rears are a different matter, the center bore on the disc is slightly bigger than the front so the spacers won't sit flush on the disc.
    Are there different sizes available? I'm running standard brakes, the center bore on the spacer is 56mm or there abouts, hard to get accurate reading as there's a recess where I need to measure
    Any advice??
    White B5 1.8 turbo sport
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    The spigot is 56.1mm.
    It has to be the same size front/rear, otherwise the wheel wouldnt fit...
    You may find the spigot on the rear sticks out further though? and is bottoming out inside the spacer?
    TD5 Land Rover Defender build
    Apr 2008
    Bracknell, Berks
    630
    Yeah you were right, there's a 10mm gap in between the spacer and the disc. Hope I can get round this by buying some decent branded spacers, not the heavy cheapo ones I've got now
    Anyone else running spacers??
    "Stick a V8 in it!"
    15,370
    I have 12mm alloy ones on the rear of Shed, but its a quattro so the hubs are different to your FWD ones.
    Apr 2008
    Bracknell, Berks
    630
    Judging by the weight of mine I think there made of cast iron! The cars not gonna be back on the road until the 1st of march so I've got time to shop about and get something half decent
  1. Brake disc size?
    By thomas-a3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th December 2011, 20:34
  2. Brake disc size
    By yellowbelly in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th September 2011, 16:39
  3. A3 1.8T quattro brake disc maximum size enquiry
    By legal_ice in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th March 2010, 12:37
  4. 3.2 Front Brake Disc Size
    By edition in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th February 2009, 18:32
  5. S4 front brake disc size?
    By Dan Gliballs in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th September 2006, 12:35
