floyd 1.8 turbo
Mirror, Signal, Outmanoeuvre
I've got some spacers to fit on the Audi, front and back both sets the same. The fronts go on perfect, sit nice and tight on the disc just as they should. The rears are a different matter, the center bore on the disc is slightly bigger than the front so the spacers won't sit flush on the disc.
Are there different sizes available? I'm running standard brakes, the center bore on the spacer is 56mm or there abouts, hard to get accurate reading as there's a recess where I need to measure
Any advice??
Any advice??
