EM TuningChris Nott
    Jun 2009
    102
    Question When did sidelight bulbs change from bayonet style to 501's?
    Hi all,
    Could anyone confirm when the B5 A4 changes from bayonet style sidelights to 501's? Was it with the facelift headlights? Mine is pre-facelift and has bayonets.
    Wondering if it's possible to change to 501's without changing headlamps?
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,628
    Must be facelift headlights as my pfl car has fl headlights in with 501s.
    Does the bayonet holder just push into the headlight? If so, cut some 501 holders off from a scrapyard and connect up and fit.
    2002 2.5 V6 Quattro
    Jun 2009
    102
    Yeah it just pushes in to a rubber grommet. I don't know if the size is comparable. I'll have a look, I have both types of bulb.
    Thanks Dan.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Mines facelift and has 501's
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,391
    I always thaught they were all 501 with the exception of Facelift S4's.
    Facelift S4's got H6W bayonets in an attempt to make the sidelights look less yellow against the HID dip beam!
    Looking at ETKA, prefacelift cars WITHOUT front fogs got T4W bayonet bulbs. The pre-facelifts WITH front fogs got a 501 wedge.
    TD5 Land Rover Defender build
    Jun 2009
    102
    I can confirm that my pre-facelift A4 has bayonets and no foglights, so that aligns.
  1. How to change A4 sidelight bulbs?
    By niftyandy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th February 2010, 11:56
  2. Sidelight bulbs in S3
    By banoffee in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th September 2009, 15:19
  3. Sidelight Bulb Change LED Style
    By cliveywolves in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th July 2008, 14:01
  4. S3 Sidelight Bulbs
    By w_inman in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2007, 14:27
  5. Sidelight bulbs
    By Aldo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th December 2006, 19:23
