Sky InsuranceAMD Technik
    41
    Post Thanks / Like
    2.5tdi lower radiator hose refitting
    Is there some special trick to getting the lower hose back on?
    I've tried dunking it in hot water and applying washing up liquid and I still can only get it half way on.
    Jan 2011
    northants
    84
    Post Thanks / Like
    make sure its clean and spray with silicone spray
    "Stick a V8 in it!"
    Cleveleys, Lancashire
    11,840
    Post Thanks / Like
    Isnt it a plastic quick release fitting?
    All the rad hoses i've ever seen on VAGs are these plastic fittings. I just give the O-Rings a little squirt of WD40 and they usually slide right on!
    For Sale: Breaking B5 A4 - Check my eBay page!
    Wanted: Facelift A4 Front Bumper with Headlight Washers.
    2000 A4 1.8T Sport Quattro Avant, Beere Pearl, TT Carriers and B6 312mm Disks.
    2000 A4 1.8T Sport Quattro Saloon, Black-ish, Now Running!
    1997 S4 - PPC £999 Challenge Track Car Build starting soon!
    Audi V8 powered Land Rover Defender build in progress.
  1. internal diameter of the top rad hose v6 2.5tdi
    By scrag in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd February 2012, 19:44
  2. Coolant dripping out, help with part/advice near lower radiator connector pls
    By Sarah's A3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th September 2011, 06:21
  3. Radiator hose clip help needed
    By tonya4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th July 2011, 11:38
  4. 20vt fwd lower intercooler hose (pancake pipe)
    By Matt82 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st June 2010, 13:53
