Sky InsuranceDPM
Thread: emissions
    Feb 2012
    northglenn, colorado
    Post Thanks / Like
    emissions
    I just bought this 98 1.8t and cant get it to pass emissions. Dont know too much bout audis and the guy i bought it from skiped titles so did never get it plated or drive it even so knows nothing bout it. I know its got a garrett t3t4 but dont know the model wich sucks cuz it needs a rebuild. It has a bov unknowen make and has a big ass front mount and 3 inch turbo back exhaust. I just had a custom intake built cuz it was leakin boost from hell with the ghetto setup the guy had on it and had the cat reinstalled for emissions. I failed on co,s and hc. I read about a spark plug fauler mod for the o2 sensor? I was goin to try this and throw some e85 in it to run emissions. Does anybody know the correct ratio? It sucks cuz i really know nothing bout the aftermarket on this car and am hoping later if i get some pics that u all might be able to help me identify some things? But first the emissions is my main concern.. thanks ahead for some advice.
    "Stick a V8 in it!"
    Cleveleys, Lancashire
    11,840
    Post Thanks / Like
    What are the HC and CO values?
    It could be an air leak, bad lambda sensor or bad MAF.
    The defouler mod is only for the second lambda sensor on later cars that have been decatted, your '98 wont have this second lambda, you cannot use it on the main lambda sensor.
    You probably need to get yourself a vagcom lead and scan the ECU for fault codes to see if theres anything wrong with it.
    Also, this forum is primarily UK based, if you visit Audizine then you might find someone local to you that can check the car over, or has the required kit to scan it for codes.
    For Sale: Breaking B5 A4 - Check my eBay page!
    Wanted: Facelift A4 Front Bumper with Headlight Washers.
    2000 A4 1.8T Sport Quattro Avant, Beere Pearl, TT Carriers and B6 312mm Disks.
    2000 A4 1.8T Sport Quattro Saloon, Black-ish, Now Running!
    1997 S4 - PPC £999 Challenge Track Car Build starting soon!
    Audi V8 powered Land Rover Defender build in progress.
  1. CO 2 emissions
    By redleg in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th February 2010, 19:22
  2. Emissions Light
    By Chewy 05 1.6FSI Sportback in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd May 2009, 10:54
  3. Emissions light!! and Value?
    By suthers in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th January 2009, 11:12
  4. Emissions
    By glen_jai in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th September 2008, 10:34
  5. S3 Emissions
    By s3bow in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd March 2006, 19:06
